Lower steering shaft bearing replacement - With pics! - Page 2 - JeepForum.com
post #16 of 92 Old 09-25-2009, 08:45 PM
ritjobbie
I did this a few months ago while I was tracking down some front end clunking. This little bearing was probably 90% of my problem. A new Borgeson shaft made a huge difference, too...
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #17 of 92 Old 09-28-2009, 10:31 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Originally Posted by cmsurfer View Post
I'm in the process of trying to replace my steering shaft and I'm having trouble getting the old one out. I dropped the steering box like shown above, but I can't move it enough to get the shaft off. It it just about there though. I think if I can get it to move less than another inch it will come off. Any ideas?
I'd rather not cut, but where exactly would I cut it?
Better try and lower your box a bit more, an inch is a little distance in this case.
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is offline
post #18 of 92 Old 11-13-2009, 11:01 AM
SouthernJeeper
Great write up. The lower bearing on the 89 YJ I just bought is !NON-EXISTANT! I can literarly bang the shaft back and forth in the steering column's outer tube that comes through the firewall. Will be replacing everything this week end, with much help from your write, which I will be printing off momentarily.
Thanks.
If I can get my down load program to work I'll post some pics to add to this thread.
SouthernJeeper is offline
post #19 of 92 Old 01-11-2010, 12:26 PM
3fourty6
Good write up. Will be doing this very soon and wondered how the shaft would come apart. I've never seen a garage floor with tile either!! Looks fancy!
3fourty6 is offline
post #20 of 92 Old 01-14-2010, 08:11 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Thank you! My garage is very small... we figured it was cheap to have tiles on the floor since it was a small space!
Fernando is offline
post #21 of 92 Old 02-26-2010, 04:37 PM
hrdcrspz
1980 CJ7
hey dude thanks a lot on this post, I have been trying for a while to take this out and replace it. question though... is the steering shaft retractable??? the dude that owned it before me did a 1 inch body lift which knocked it out of place by just enouph for me to be able to turn it a little bit and get stuck to where I can do circles all day with my hands off the wheel haha . The shaft seemed to get stuck on the inner part of the wheel well. it looks retractable but im just not sure if its just rusted shut. I am hoping it is because I cant find a steering shaft extender anywhere.
hrdcrspz is offline
post #22 of 92 Old 02-26-2010, 05:43 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
I am not totally sure but I believe on some models it is retractable, but rust and grime will get it stuck. However your case is different because of the body lift, the shaft should not make contact with the inner part of the wheel well... Can you take some pictures of that and post them?
Try using a hammer to get it loose, careful not to ruin the shaft, hit it hard but not extremely hard, some PB Blaster will help too. You may have to remove the whole shaft if it decides not to budge.
Good Luck!! Keep us posted
Fernando is offline
post #23 of 92 Old 02-26-2010, 06:33 PM
hrdcrspz
1980 CJ7
thanks for the reply. unfortunately I already took it out. I will try what you said though... I already tried the hammer it seems to not want to budge. The lower part of the steering shaft is smaller and looks like it slides into the upper part
hrdcrspz is offline
post #24 of 92 Old 03-26-2010, 09:26 AM
JW-YJ
Thanks for this, I just purchased my jeep and got it home and it's leaking there.. I figure that's the problem. Great post.
JW-YJ is offline
post #25 of 92 Old 03-26-2010, 09:53 AM
Louie4
What's leaking out of it? Shouldn't have liquid coming out from there. If the bearing is bad you can tell by grabbing the steering shaft and trying to move it back and forth. If you have a lot of play up there its bad.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #26 of 92 Old 03-26-2010, 10:15 AM
JW-YJ
Thanks for the response, it is a clearish oily fluid that is leaking from the steering box as far as I can tell. Any insight?
JW-YJ is offline
post #27 of 92 Old 03-26-2010, 10:59 AM
Opihi59
from here it gets rough
Opihi59's Avatar
The clearish oily fluid is likely power steering fluid. It isn't likely you have a leak from the steering box per se, it is likely that you have a leak of power steering fluid probably from the high pressure hose side. Wipe everything down, power spray it off etc, let it dry and see if you can home in on where the leak is.
Check your power steering reservoir to make sure it has fluid in it, top it off if necessary. Check for cracks in the reservoir that may dribble down a hose and masquerade as a leak from below.
My bet is that it is your high pressure hose leaking. Part is readily available, but it a pain to get to the fitting on the lower end.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #28 of 92 Old 03-26-2010, 11:18 AM
JW-YJ
My 95 YJ doesn't have power steering, that was my first thought, however this is my first car w/o power steering. Would the car still have a steering fluid reservoir? I haven't had a chance to even get under the car yet or in the engine it's not even a day old for me yet. Thanks!
JW-YJ is offline
post #29 of 92 Old 03-26-2010, 11:39 AM
Opihi59
Opihi59's Avatar
Okaaayyyy Scratch that idea.
No power steering, no power steering fluid. Try to isolate the origin of the leak and let us know. It is possible for the steering box to leak, there is a seal/seals in it etc but I honestly do not know what type lube/fluid is in Jeep steering boxes. Hopefully someone else will chime in.
Opihi59 is offline
post #30 of 92 Old 03-26-2010, 11:55 AM
Louie4
Just to clarify, are we talking about the steering box or the upper part of the shaft where the column comes through the firewall?
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
Lower Steering shaft replacement EnFuegoUno YJ Wrangler Technical Forum 14 10-24-2009 07:15 AM
Lower Intermediate Steering Shaft Pics cntryboy JK Wrangler Technical Forum 0 05-20-2009 10:43 AM
Steering Shaft and Bearing Replacement ech0sh4y YJ Wrangler Technical Forum 6 11-18-2008 09:09 PM
steering column lower bearing replacement azgurney YJ Wrangler Technical Forum 10 03-18-2008 06:12 PM
how to replace lower steering shaft & bearing??? raStapiMpjaY YJ Wrangler Technical Forum 0 04-02-2006 01:51 PM
