Lower Shock mount replacement & New Shocks - JeepForum.com
post #1 of 3 Old 09-03-2012, 07:51 AM Thread Starter
Plyj
I always come here for the best advice... so here goes -
I just replaced the lower shock mounts (welded to axle housing) on my stock '90 YJ (one was rusted through so I did both). The replacement brackets looked about 3" shorter than the OEM (they were the only ones I could find) so the rear now sits about 3" taller than standard height (and I'm probably not getting full travel/damping effect). Since this is, essentially, a road/highway vehicle, I'd like to bring it back down to stock height & need to figure out what height shock absorber I need.
Should I just go to auto store and tell them I want a shock absorber that's 3" shorter"?
Is there a way to figure out exactly what I need by measuring from top to bottom mount and dividing, etc.?
Should a shock absorber at rest be at the mid-point between fully expanded and fully closed?
Any help appreciated... thanks
Plyj is offline
post #2 of 3 Old 09-03-2012, 09:30 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
There are two options that are about the same cost but will gain different results. The first is obvious. Flex out your suspension and measure the fully extended and fully collapsed points of the rear shock tabs, then give that info to your shock monger and he should be able to get you the shocks you need that will not bottom out and break something. The other option is if you paid good money for your current shocks and want to avoid spending money on them again.
Teraflex makes this rear shock bar that's designed to maximize travel in tight spaces. There are three adjustments on it for different travel shocks. I'm sure one would work with your current shocks. On the teraflex website, it's selling for $25 and for another $25 you pick up the adapters for the bottoms to change the direction of the shock. It's cheaper than a new set and is a viable option for some.
Luck Favours The Prepared
Anticanman is offline
post #3 of 3 Old 09-03-2012, 10:06 AM Thread Starter
Plyj
Okay... thanks.
That's about what I thought.
My present shocks, though still functioning okay, are about 6 years old so I'll probably just go the new shock route.
Again... thanks for your help.
Plyj is offline
shock absorber , shock length
Front right shock lower mount PrinothPro YJ Wrangler Technical Forum 11 12-24-2011 03:31 PM
How to fix rear lower shock mount? chrishag YJ Wrangler Technical Forum 9 09-11-2009 10:24 AM
Rear Lower Jeep Shock Mount mmarmouz TJ Wrangler Technical Forum 26 08-19-2009 12:37 PM
rear lower shock mount Bluebear YJ Wrangler Technical Forum 4 05-31-2008 11:09 PM
Idea for lower shock mount relocation opticalwaveguy TJ Wrangler Technical Forum 1 08-06-2006 09:47 AM
