Low fuel pressure - JeepForum.com
post #1 of 5 Old 06-21-2010, 09:27 PM Thread Starter
smithjeep11
Low fuel pressure
I have an 89 YJ with 4.2 258i and stock fuel system. I have recently replaced the fuel pump and fuel filter. I recently checked the fuel pressure and found it to be between 1 and 2 psi. This seems very low. What is the fuel pressure suppose to be? What could be causing this?
smithjeep11 is offline
post #2 of 5 Old 06-21-2010, 09:45 PM
monkeyhouse
Originally Posted by smithjeep11 View Post
I have an 89 YJ with stock motor and stock fuel system. I have recently replaced the fuel pump and fuel filter. I recently checked the fuel pressure and found it to be between 1 and 2 psi. This seems very low. What is the fuel pressure suppose to be? What could be causing this?
did you get that on the rail at the schrader(sp) valve? if so, yes, that's low...heck that's low at the carb.
First Jeep was an 1989 YJ, 6 cylinder 4.2L , 258. Nuttered and TeamRushed, Weber 38 DGES, Now, I'm venturing into the world of Grand Cherokees
monkeyhouse is offline
post #3 of 5 Old 06-21-2010, 10:22 PM
MJMPC
Fill out your jeep info so we know what you have.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #4 of 5 Old 06-21-2010, 10:28 PM
monkeyhouse
Can't believe I missed that man. Thanks for havin my back, lol
post #5 of 5 Old 06-21-2010, 11:58 PM
MJMPC
That helps alot have you checked your fuel filter ? Make sure it is mounted right.
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
How to test fuel pump/fuel pressure on '05 4.0L Zen TJ Wrangler Technical Forum 18 05-12-2010 08:34 AM
Fuel pressure too high - Fuel return line problems ChiroSean YJ Wrangler Technical Forum 4 08-11-2009 09:57 AM
High fuel pressure at the fuel rail ChiroSean YJ Wrangler Technical Forum 5 12-17-2008 01:02 PM
98 tj fuel pressure 98zjteen TJ Wrangler Technical Forum 13 08-18-2006 04:15 PM
Fuel Pump !!! No Pressure at Fuel Rail!!! turfman* YJ Wrangler Technical Forum 2 11-18-2002 10:26 PM
