Low compression - JeepForum.com
post #1 of 5 Old 04-12-2007, 04:23 PM Thread Starter
wrangler94
Low compression
I have a 94 with 2.5l. It has low compression in #2 & #3 cyls. It only has 86000 miles on it none of which are hard driven miles. I've heard of a product you can use to unstick piston rings for a better seal, pls someone let me in on the secret of this mystery fluid. Plus, how long will this work. I will be doing a complete overhaul of the engine in the future, but for now the timing and the funds are not available. Any help will be greatly appreciated.
Thanks
wrangler94 is offline
post #2 of 5 Old 04-12-2007, 05:55 PM
Ares
Ares's Avatar
Thanks
Hmmm, there are some chemicals you can try in your local store. I think one is Restore...comes in a silver can, supposed to be pretty good. But the only way to really restore your compression is by replacing the rings and cleaning the cylinders/pistons. Remember, its not always your rings fault for low compression
- Cameron
Ares is offline
post #3 of 5 Old 04-12-2007, 06:10 PM
kloppk
One possibility is that the head gasket is blown between cylinders 2 & 3 causing poosr compression on both cyls.
kloppk is offline
post #4 of 5 Old 04-12-2007, 06:37 PM
drew2000
drew2000's Avatar
How low is low?
Drew
1994 YJ - 2.5L, 2" BDS w/1" Shackles
2006 Dodge Charger R/T (5.7L Hemi)
drew2000 is offline
post #5 of 5 Old 04-12-2007, 08:27 PM
Smash209
Smash209's Avatar
Any chance you might share your secrets?
All in all, i'm not much of a believer in additives, except for maybe fuel-injector cleaner.
Smash209 is offline
What should my compression be? 2.5l tawdr77 YJ Wrangler Technical Forum 18 01-18-2010 12:27 PM
low compression cyl 1 wanabejeeper YJ Wrangler Technical Forum 7 09-21-2009 05:42 PM
Full compression in front, no compression in rear Caceman YJ Wrangler Technical Forum 5 05-20-2009 08:00 PM
4.2 compression JJ-4 YJ Wrangler Technical Forum 2 12-01-2008 08:39 PM
Compression PSI King03Kev YJ Wrangler Technical Forum 12 11-07-2006 10:06 PM
