Quantcast Loud squeeling - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Loud squeeling
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 04-14-2002, 03:43 PM   #1
vajeeper
Loud squeeling
I have a loud squeeling noise coming from under the hood of my 1992 4 cyl YJ. The higher the rpm's the louder it is. It will go away for a while but after a few minutes the noise is back. The noise appears to be coming from the alternator, but i'm not sure. I sprayed the alternator and belt with super lube and the noise went away. After a few minutes the noise came back very faint and then continued to get louder. Does anyone know what might be causing this?
vajeeper is offline   Reply With Quote
Old 04-14-2002, 03:54 PM   #2
Drunc
is it only after cold starts??
I have the same thing...it's the alternator belt...if it's old, then it probably needs replacing
Mine's old and shrunk a little, so I just need to get around to changing it
Jeep: '88 YJ Laredo I6, Kenwood Deck, Amp and 6x9's, 10" pioneer sub, 2.5" Skyjacker Kit with a 1" body and new front shackles, 32" Mud Kings on 8" Desert Crawlers, CJ style replacement mirrors, ditched the trackbars and the endcaps
Drunc is offline   Reply With Quote
Old 04-14-2002, 07:21 PM   #3
grantnps
If its not the alternater. it is probably the starter. It happened to me and its an easy fix.
'94 YJ 4 banger :( 4" ProComp suspension 32x12.5 a/t's, flow's, kn air filter charger, and lots of little appearance mods.
grantnps is offline   Reply With Quote
Old 04-14-2002, 08:11 PM   #4
vajeeper
It happens after cold and hot starts. I'll try changing the belt and see if it makes a difference. Thanks for the input.
Old 04-14-2002, 08:37 PM   #5
4wheeler4CJ
Most likely the belt. Mine was doing it also, but had 90,000 miles on it, so it was long overdue, as I was slowly peeling outer layers away, LOL <img border="0" title="" alt="[Eek!]" src="eek.gif" />
After you put your new one on, it will stretch after a few days. The following week, retighten it (if you have adjustment, it is on your idler pulley mounted to the power steering pump). If you simply have a pre-tensioned idler, there is no adjustment. Check your manual. <img border="0" title="" alt="[Wink]" src="wink.gif" />
4wheeler4CJ is offline   Reply With Quote
Old 04-14-2002, 09:53 PM   #6
MusicMaverick
2010 JK Wrangler
My belt broke, and I replaced it, THEN it started squealing, make sure your tention is tight enough. There are ajustments over on the driverside of the the belt path
Currently:
2010 Wrangler Sport
Past vehicles:
1992 YJ
1997 TJ
MusicMaverick is offline   Reply With Quote
Glock Forum
