Loud knocking noise when turning - JeepForum.com
post #1 of 4 Old 08-31-2012, 12:54 PM Thread Starter
jeeprookie15
1987 YJ Wrangler
Yesterday I put my jeep in 4wd just to make sure it still worked and then put it back in 2wd. When I took off down the road, I noticed it sounded a little different when I got up to about 30-40 mph kind of like a slight grinding metal noise, but nothing really loud. I messed around with the 4wd some more to make sure that it wasn't still engaged, but now, whenever I turn my jeep will make a loud knocking/clunking noise. It makes this noise in 4wd and 2wd. I noticed the vacuum hose (I think that's what it's called) came loose so I hooked it back up but the jeep still makes the noise. Any ideas of what may be the problem?
jeeprookie15 is offline
post #2 of 4 Old 08-31-2012, 06:38 PM
rodgers3
Most likely your exhaust pipe is rubbing the front drive shaft.
rodgers3 is offline
post #3 of 4 Old 08-31-2012, 07:03 PM
sdotcarter
Your front u joints tireside?
sdotcarter is offline
post #4 of 4 Old 08-31-2012, 08:10 PM
USMCBuckWild
Did you hook the vacuum lines up backwards? If so, the slip shaft (?? Correct terminology) that locks the passenger side axle shafs together will be engaged. Maybe this will cause everythin in the diff to spin and give you a clunking from the axle shafts spinning?
USMCBuckWild is offline
4wd , knocking
Loud knock noise when turning wheel... Mudbug1979 TJ Wrangler Technical Forum 3 03-09-2009 06:56 PM
loud knocking noise TopThrillJoe TJ Wrangler Technical Forum 7 12-14-2007 04:01 PM
loud knocking noise diagnosis arrow8807 YJ Wrangler Technical Forum 1 07-01-2007 12:52 PM
knocking noise when turning wheel ohhpe YJ Wrangler Technical Forum 5 12-07-2005 08:07 PM
knocking noise while turning mikevsgeek TJ Wrangler Technical Forum 10 05-17-2005 09:08 PM
