Loud clicking from engine under load - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Loud clicking from engine under load
ROCKRIDGE 4WD Newsletter about to hit your Inbox! Just in FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitUSA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 06-22-2014, 08:00 PM   #1
lower7
I am getting a loud clicking sound from my engine when i pull a grade. I had originally thought it was transmission related but have ruled that out with my AX15 swap and new clutch.
Do any of you engine gurus have a thought about what is going on in there? I have 175K on the clock. Is it getting ready to go on me?
Thanks,
John
lower7 is offline   Reply With Quote Quick reply to this message
Unread 06-22-2014, 11:36 PM   #2
LJameson
Detonation?
What's your timing set at?
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline   Reply With Quote Quick reply to this message
Unread 06-23-2014, 07:18 AM   #3
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
I use the phone android app so can't see profiles or SIG lines. Just guessing that your timing might be advanced too much if you have the 258. That said, the CJ owners manual on the 258 states it is supposed to rattle under load on a hill. This is normal and a sign that you need to downshift. If it still pings under heavy load or running hot, the manual recommends high test gas.
I got 5 mpg better running high test on my 258 with the timing set to 9 btdc with way better throttle response. I figure an extra 100 miles per tank was well worth the extra $7.00 or so a fill.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 06-23-2014, 11:40 AM   #4
Shadownwpa
check your intake and exhaust gaskets for leaks
http://www.jeepforum.com/forum/f22/shadownwpa-91ish-yj-build-thread-1857154/
Shadownwpa is online now   Reply With Quote Quick reply to this message
Unread 06-23-2014, 11:56 AM   #5
bpounds
bpounds's Avatar
I agree that it is probably pinging - detonation - knock. All terms for the same thing.
The key is the Howell EFI kit. I've been tweaking my timing after the Howell install. The engine originally had a knock sensor which would retard the timing as needed to avoid knock.
Now you don't have a knock sensor, and the GM throttle body ported vacuum source connected to the distributor vacuum advance has a different pressure profile than the stock Carter carb. Plus you have eliminated the PCM and the ICM no longer has the ability to adjust timing for you. You have to go old school on it.
I'm still working on exactly where I want mine. But to stop the pinging it is an easy adjustment. Get a 1/8" allen wrench. Pull the vacuum hose off the distributor. Stick the allen wrench in the vacuum nipple and find the set screw. Turn it counterclockwise about 2 turns. Then test drive. Go another turn, test, repeat as necessary until the pinging under load just stops. Count the total number of turns and make a note for yourself so you can reverse it if you don't like the result.
Then research timing profiles over in the CJ forum for more in depth instructions on perfecting the timing mechanical and vacuum advance. The above should be used just to prove that it is indeed pinging, and not something else. The CJ forum has better info on the 4.2 than the YJ forum.
Bill
Dodge did not build my Jeep.
1988 Wrangler,4.2L I-6, Howell EFI JP-1, 5 Speed Peugeot, Zone 2.5" lift + 1/2" booms, BFG 31 x 10.5, Bestop.
bpounds is offline   Reply With Quote Quick reply to this message
