Quantcast Lots Of Questions..... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Lots Of Questions.....
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 09-23-2008, 11:40 PM   #1
oompaloompasc3
Well I have alot of questions so i figured i would ask all at once....
I was looking at a set of blue torch fab bumpers. does anyone know of any info on quality of these bumpers?
I currently have 35's on the jeep and would like to get some gears. I know everyone is going to say 8.8 but will the d35 hold if it is built? most likely a 4.88 gear will be going in there with lock rite lockers front and rear...
Another question i have is i am going to be moving my spare tire into the cab and get rid of my back seat. how hard is it to move the battery back there also? what all is involved also if i run dual batteries do i have to upgrade the alternator? does the dual battery kit have to be purchased?
I got a quote on the gears and the guy is saying about 1800 with gears and front and rear lock rite lockers.... does that sound fair?
1994 Jeep Wrangler SE 4.0 manual, AEM Brute Force Cold Air Intake, Red Optima, Banks Chip, Banks Header, Custom Downpipe, Flowmaster 50 Series, 35x12.50.15 BFG All Terrains, Black Steel Wheels with Simulated Beadlock, 3" Rancho Suspension, 3" BL, 3/4" brandon_yj Shackles, Line-X everywhere, So much more to do....
oompaloompasc3 is offline   Reply With Quote
Old 09-24-2008, 07:42 AM   #2
champelite210
Don't know on the bumpers.
No on the Turdy-Five.
Just a matter of running some heavy gauge wire and a way of locking down the batteries.
1800.00 if that includes the lockers, gear parts and labor, then yes. In my opinion
1998 TJ, 4.0 HO, 5 speed, 3.5" RE Super Flex Adj SA lift, AA SYE, Currie steering, 4.88 Gears, 8.8 Rear with Eaton E-Locker, HP Dana 30 with Detroit locker and chromoly shafts, 36x12.5x15 TSL-SX, TNT Customs front 3.5 fenders, XRC rear crusher corners with 3.5 flare, A to Z rock sliders, PSC steering pump.
champelite210 is offline   Reply With Quote
Old 09-24-2008, 08:24 AM   #3
oompaloompasc3
whats a size gauge should be able to be ran? 2 gauge? it should just be grounded to the frame right?
Old 09-24-2008, 08:46 AM   #4
MLJeeper
MLJeeper's Avatar
Blue torch makes good stuff.
As for the Dana 35, define what YOU mean by built.
You can buy relocate kits for the battery at places like Summit racing that make moving the battery a breeze.
Price on installing the gears and lockers is way high in my opinion.
Your limited slip differential sucks.
MLJeeper is offline   Reply With Quote
Old 09-24-2008, 11:23 AM   #5
champelite210
Really, I did a quick figure on all the parts needed and here is what i came up with.
2 loc rite lockers 600.00
2 sets gears and install kits 600.00
2 carriers 150.00
That leaves 450.00 for labor on both axles.
I thought that was pretty decent.
Old 09-24-2008, 11:50 AM   #6
Jim93YJ
Jim93YJ's Avatar
2 carriers 150.00
That IS a good deal on the labor assuming the guy knows what he is doing. I recently regeared my D30 to 4.56 and you will be hard pressed to just spend $450.00 on getting some decent tools you need just to do the job yourself not to mention what your own time is worth.
93YJ 2.5L,AX15,Atlas 4.3:1, 4.56 Gears, Dana 30 w/ Posi-lok,Dana 44 Rear w/ Ox Locker + 99 Explorer Disk Brakes,Tom Woods D. Shafts,1" Body, 2.5" ED RE Lift, 31" Pro Comp M/T's with MT Classic II Wheels, Herculined Inside, Flexalite Fan,4.0L Throttle Body, 20 Gal Tank Conversion,Tuffy Center Console,Warn Front Bumper, Rockhard 4X4 Rear Bumper w/ Tire Carrier,Bestop Extended Flares,AMSoil/Redline In Everything and the List Goes On....
AND...
88YJ 4.2L: Interior and mechanical overhaul including engine replacement, nutter bypass, Weber 34 Carb, and work on a whole bunch of other things to get it back to fine running condition without the emissions control...evap cannister kept functional as well as PCV system, and manifold heater.
Jim93YJ is offline   Reply With Quote
Old 09-24-2008, 12:29 PM   #7
MLJeeper
MLJeeper's Avatar
well i would go aussies first of all at $240 a pop. Better locker in my opinion too.
A gear and install kit wont run you more than $200 each and thats retail
$150 on a pair of carriers.
Looks closer to 700 for labor to me. Plus the guys probably getting a wholesale or discount price on the parts.
Glock Forum
