Lots of metal in my AX-15 - JeepForum.com
post #1 of 4 Old 07-19-2004, 10:42 PM Thread Starter
SteelKJ
This sounds expensive, but I've got about 1/4 inch of metal shavings magnetized to my drain plug on the AX-15. When I drained the oil it came out looking like day old chocolate milk!
I noticed on my way home from work that when I eased off the gas in 1st and 2nd and let the engine slow me down it made a nice metalic grinding noise. This prompted me to do the oil change. Is this more than just replacing the syncros? Or should I look at finding a newer or rebuilt tranny?
I'm gratefull for any advice you've got to offer, I'll need all the info I can get before I let my wife in on the bad news.
[Edit]
I've been thinking maybe now is a good time to swap out the engine for something newer. I've searched the board and think that a engine and tranny from a 95-96 would be a good replacement. Would this be a direct bolt in for a 91 YJ? Is there any little pieces that I should be aware of when doing this type of swap?
Thanks
SteelKJ is offline
post #2 of 4 Old 07-20-2004, 10:36 AM
CanukYJ
CanukYJ's Avatar
Not sure on the swap but with the tranny the grinding may mean the bearings are finished or it could have just been the noise the water\oil mix was making not lubing the bearings right. I changed the oil in my ax5 and found a lot of metal in there, it just happens in trannies, so it –may- not mean it’s toasted. Why not just get some GOOD tranny oil (redline, or quaker state syncromesh gl 3\4 80w90) and dump it in (use some regular gear oil to flush out the rest of the water, see the other post floating in here about that one) and see what happens. There may be more lift left in it than you think and it will buy some time so you can consider the swap.
My jeep has only ever killed 3 things, a cat, a deer, and my wallet. What's the problem officer?
1992 Red YJ. Lifted, locked, and loaded with beer (Disclaimer: This doesn't mean said driver endorses drinking and driving, please enjoy alcohol responsibly and do not operate any vehicle of any kind, thank you....)
Thanks to the price of gas here ($4.25 a gal) I just bought a mountain bike, 0" of lift, 0" of travel, MT's, locked rear axle, oh yeah, it's the sh#$.
CanukYJ is offline
post #3 of 4 Old 07-20-2004, 03:51 PM Thread Starter
SteelKJ
Thanks CanuckYJ, I'll try flushing the tranny before I go any further. I checked with a few local shops and they wanted anywhere from $750 to $1000 (Can) to rebuild it. Damn these things are expensive!
If I decide to replace the AX-15 from another vehicle, would any vehicle work or is each model a little different?
SteelKJ is offline
post #4 of 4 Old 07-20-2004, 04:05 PM
CanukYJ
CanukYJ's Avatar
ALL jeeps should use the same AX15 from what I understand and I know –some- years of dodge dakota’s have them too but I don’t know a lot about the Dakota years. Good luck and hope the flush works out for the better.
CanukYJ is offline
High-pitched metal/metal squeal during acceleration... BoneyMan TJ Wrangler Technical Forum 49 08-17-2016 08:30 AM
light screech squeal at start up, metal on metal sound not moving rutacon05 TJ Wrangler Technical Forum 3 12-07-2009 01:06 AM
lots of metal flake in my D30...Why? danheit TJ Wrangler Technical Forum 6 07-17-2008 12:59 PM
metal to metal sound when brakes are applied mrgan TJ Wrangler Technical Forum 12 02-07-2008 07:47 PM
Clink noise in linkage (metal on metal) on shift. Christian T TJ Wrangler Technical Forum 1 10-05-2004 01:22 PM
