A lot of slop in my steering? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > A lot of slop in my steering?
New! JK/U skid plate system.We now have Uniballs!The Original 3/8" Ruffstuff Diff Cover!
Unread 03-14-2014, 11:38 AM   #1
jeepster93
My steering is bad.
Almost a quarter turn of slop, where the steering wheel moves but the tires do not.
I have modded my steering to a heavy duty tie rods and rod ends, requiring me to drill out the steering knuckles.
So..
I jacked up the front tires, one at a time.
And wiggled them hard. Up and down, side to side. The standard shade tree test for this kind of thing.
Did not find really enough things loose to account for the steering issue.
Kept looking. Found the pitman arm has a dead spot in it of about an eighth of a steering wheel turn, before the drag link starts moving. I think this is because I have an extended pitman arm, the one that came with the lift, and after the mods, I should be running the stock one(will deal with this).
Kept looking. Found this:
This is my steering wheel as it comes out of the firewall(top of the pic) and goes to a u-joint(bottom of pic) then to a shaft to the power steering pump.
It moves, a lot.
My slop?
What is broken? Or missing?
How would I repair this?
That cap/cover thing that moves a lot does not move into the place the steering wheel is.
jeepster93 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 11:43 AM   #2
Rproject
Rproject's Avatar
1987 YJ Wrangler
I have the exact same problem, except mine creates a bit of a crunching noise on occasion. No real slop added to mine from this - I think.
I had a ton of slop from my steering gear box. When I replaced it, almost all my slop went away. How far does your steering shaft rotate before it picks up in the gear box? Something in your gear box might be loose.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread: http://www.jeepforum.com/forum/f22/r...hread-2164793/
Rproject is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 12:31 PM   #3
imstillatwork
You're looking at a broken (for a very long time it looks) steering shaft bearing.
imstillatwork is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 12:41 PM   #4
92 Green YJ
I have the exact same issue with my YJ at the moment and found the very same issue. I also know my steering shaft joints are pretty well shot. Haven't gotten to tearing into it yet to see what exactly broke and needs to be replaced.
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My RigRater Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 01:28 PM   #5
PA_YJ19
Yep, like stated above. U need a lower steering shaft bearing, trust me it'll make a world of a difference. Replacing that fixed the slop in my steering altogether.
PA_YJ19 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 01:45 PM   #6
Louie4
Powah Injanir
Louie4's Avatar
You found the problem.
Here is the solution:
Lower Steering Shaft Bearing Replacement
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline   Reply With Quote Quick reply to this message
Unread 03-14-2014, 03:15 PM   #7
jeepster93
That "how-to" helped. I was wondering how it came apart.
The new bearing is available and about $35.
I will replace it.
Unread 03-14-2014, 05:24 PM   #8
Rproject
Rproject's Avatar
1987 YJ Wrangler
I just ordered mine as well. I'm really glad you started this thread. Thank you.
1996 White ZJ
Unread 03-23-2014, 06:17 PM   #9
Rproject
Rproject's Avatar
1987 YJ Wrangler
Got my new bearing kit in today. Replacement went well, except for the cap. Although the bearing and sleeve were seated, the new cap didn't want to fully seat. Used the old cap and it for fine. :-)
1996 White ZJ
Unread 03-24-2014, 05:14 AM   #10
rykerjenbob
Have to do mine this spring. Tried to get the bolts out for the steering box, no go. Tried to get the lower shaft out, but it is rusted solid. Gonna have to cut the shaft and get a new one along with the bearing. Shaft is worn anyway.
rykerjenbob is offline   Reply With Quote Quick reply to this message
Unread 03-24-2014, 06:20 PM   #11
UZI4U
I HATE THIS SITE!!
Every time I think everything is kosher, something like this pops up and makes more work for me.
Thanks for pointing this out...I would have never considered checking a bearing at that end of the column.
MCLMM
UZI4U is offline   Reply With Quote Quick reply to this message
