Lost tach, speedometer, & gauges - JeepForum.com
post #1 of 1 Old 04-07-2009, 08:23 PM Thread Starter
dadickster
I have a stock 94 YJ with the 2.5 motor & 5 speed transmission. I rode in an area that had just been logged. When I got home my jeep wouldn't crank. I got under the jeep and find the wire on the solenoid pulled off. I replaced the starter, but it wouldn't crank. the battery was fine but the starter wouldn't make a sound. I took it to my mechanic and he found a wire hanging (close to the o2 sensor) comming out of the passenger side of the transmission. He spliced it back together and the jeep cranked. On my way home I realized my tach, speedometer, and other guages weren't working. I went back to my mechanic. He said it must be the wires he spliced. He looked up the part saying it is a transmission jumper. He called a jeep dealer who said it is 94specific and no longer made.
Thoughts or suggestions please.
Thanks
dadickster is offline
Speedometer, Tach, and Cluster Gauges Not Working PanthrosRevenge YJ Wrangler Technical Forum 19 04-03-2016 06:32 PM
Lost Power to Speedometer, Tach, Oil.. etc. / Dome Lights on 1997 TJ MikeyJeepNJ TJ Wrangler Technical Forum 4 03-14-2009 12:54 PM
speedometer and rpm tach 94SOAYJ35 YJ Wrangler Technical Forum 1 05-18-2006 11:05 PM
Lost speedo and tach 99jeepsport TJ Wrangler Technical Forum 2 06-01-2005 10:38 AM
tach needs fixed and I'm lost... Timmy.o.tool YJ Wrangler Technical Forum 2 04-06-2005 11:16 AM
