Lost keys, had key to locking gas cap, what do I do!!!!???? - JeepForum.com
post #1 of 25 Old 05-22-2009, 11:50 PM Thread Starter
hotzy21
Hey so like a moron, I lost my keys tonight. Unfortunately for me, my gas cap key was on it. I have no idea where to go from here. Locksmith maybe to get the gas cap off, but can I replace it with a normal gas cap? Can I buy replacement jeep gas caps? Any ideas? Any thoughts are appreciated, thanks a lot.
hotzy21 is offline
post #2 of 25 Old 05-23-2009, 12:24 AM
ImpactFabWorks
You can go to any auto parts store and find a new gas cap. Locking or non locking and it should be under 10 bucks
ImpactFabWorks is offline
post #3 of 25 Old 05-23-2009, 06:21 AM
oteps
1980 CJ5
Buy a new gas cap. Have a locksmith remove the old cap or start drilling, the tumblers are brass and drill easy just dont break the bit off in there. After you drill the key hole a while you can use a screw driver to turn the lock.
oteps is offline
post #4 of 25 Old 05-23-2009, 07:32 AM
Jeepsr4me19
1976 CJ5
Just stick a flat tipped screw driver in. Most times that works without drilling.
Jeepsr4me19 is offline
post #5 of 25 Old 05-23-2009, 07:37 AM
89YJmoneypit
KMG365
89YJmoneypit's Avatar
You can get to the filler neck from underneath pretty easily. Remove the hoses, unscrew the black plastic trim piece behind the license plate, and pull it and the neck out. Then you can either get a new/used filler neck or try some of the methods already suggested without fear of getting stuff in the tank.
89 YJ
Transplanted '99 4.0, AX-15, NP231
Red Jeep club #8
Now belongs to my daughter.
97 ZJ Laredo
4.0, 42re, NP242
R.I.P.
Marseilles Fire Dept:
89YJmoneypit is offline
post #6 of 25 Old 05-23-2009, 10:57 AM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
just about to suggest that. id take that route.
Thomas
-1987 YJ
Tompatt is offline
post #7 of 25 Old 05-23-2009, 10:59 AM
nyquiljunkie
If its a plastic locking cap, a claw hammer makes short work of it.
The Jeeps are hers. The tools are mine. She drives them, I fix them. Lucky me.
nyquiljunkie is offline
post #8 of 25 Old 05-23-2009, 11:29 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I would go this route first either way... don't want to be cutting / drilling and have shavings fall into your gas. It will make short work of your fuel filter.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #9 of 25 Old 05-23-2009, 01:26 PM
Jeepsr4me19
1976 CJ5
The cap is sealed on the bottom. You dont even have to drill that deep. So no shavings going in,. hell the dirt and crude from taking the hose off is more likely to fall into the tank. Jam a screwdriver in and twist. those locking caps are meant to keep the honest guy out. The locking tabs are weak and will bend when you turn it with the driver in it. I just took one off last week. the top part of mine came off and I was able to slide a flat tip in and pop it loose.
post #10 of 25 Old 05-23-2009, 01:58 PM
Tompatt
Tompatt's Avatar
1987 YJ Wrangler
hey while the filler is already out... you could just put a TJ filler in there and put it on the side. nice mod. no more gas nozzles flying back at you.
Thomas
-1987 YJ
Tompatt is offline
post #11 of 25 Old 05-23-2009, 03:07 PM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Does the cap just spin when you try to turn it? (I never had one, don't know.) If so, just drill through the top off to the side, but so the drill would still be heading into the pipe, and put a nail into the hole (or leave the drill bit in). The outer cap should then be 'pinned' to the inner threaded plug and both just turn out.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #12 of 25 Old 05-23-2009, 03:21 PM
kirksjeep
Nice idea. If I ever loose the key to mine I might try it.
kirksjeep is offline
post #13 of 25 Old 05-23-2009, 07:01 PM
Lumpymayo
I had this problem once when my father bought a truck from an auction. I studied it for a while, and was able to turn if off with no key. I simply just pressed hard on the cap and turned it left at the same time, kinda like those child proof caps. Give it a shot, it might work.
Lumpymayo is offline
post #14 of 25 Old 05-23-2009, 10:25 PM
oompaloompasc3
I use to work at advance auto and we had many people do this. Most of them are keyed alike so just go and ask to try a few keys to see if it unlocked. People would get so pissed bc they were keyed alike but its just a thought for you to try. Seen it work alot of times.
1994 Jeep Wrangler SE 4.0 manual, AEM Brute Force Cold Air Intake, Red Optima, Banks Chip, Banks Header, Custom Downpipe, Flowmaster 50 Series, 35x12.50.15 BFG All Terrains, Black Steel Wheels with Simulated Beadlock, 3" Rancho Suspension, 3" BL, 3/4" brandon_yj Shackles, Line-X everywhere, So much more to do....
oompaloompasc3 is offline
post #15 of 25 Old 05-26-2009, 05:28 PM
89YJmoneypit
KMG365
I wonder if the OP blew himself up
89 YJ
Red Jeep club #8
97 ZJ Laredo
4.0, 42re, NP242
R.I.P.
Lost Keys PrinothPro YJ Wrangler Technical Forum 4 11-02-2009 04:43 AM
lost my keys rocklee YJ Wrangler Technical Forum 2 05-09-2009 12:54 PM
Lost Keys....How to get replacements??? RckyMntnKng YJ Wrangler Technical Forum 5 05-10-2006 12:44 PM
! Lost Keys ! opticalwaveguy TJ Wrangler Technical Forum 9 10-21-2005 05:20 PM
Silly me, lost my keys wingzero1285 TJ Wrangler Technical Forum 9 04-09-2003 01:09 PM
