lost ignition key - JeepForum.com
post #1 of 15 Old 11-12-2010, 06:48 AM Thread Starter
hurricane99
lost ignition key
i lost my only key to my jeep and i was wondering were do i get a replacement one made. can ace or walmart do it or will they need a copy? any tricks or advice would be great thanks
1989 jeep wrangler. bone stock jeep 4.2l inline 6 backed by a peugeot 5 speed and np231 tcase.
hurricane99 is offline
post #2 of 15 Old 11-12-2010, 06:58 AM
muddy93
1987 FSJ Wagoneer
Places like ACE, and Walmart will need a key to coppy. You might try calling the dealership, I know they can cut keys for newer cars if you give them the vin. However, I don't know if they can do that for older vehicles.
Worst case, just get a new key cylinder w/keys, and swap it in.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 15 Old 11-12-2010, 07:07 AM
BigBass
The dealer probably won't be able to help you with a jeep that old. You can change the whole cylinder in the column or just have a locksmith cut you one.
All Long Islanders Check out OutLawedOffroad.com throw my user name BigBass in the referral box
BigBass is offline
post #4 of 15 Old 11-12-2010, 09:42 AM
jeep16
or use a paper clip lol
jeep16 is offline
post #5 of 15 Old 11-12-2010, 09:58 AM
ziebartrob
The Jeep dealer can cut one off the vin #. I just had this done about 4 months ago for a customer with a 1990 Caravan. It cost about $11.00.
Originally Posted by Mymmars
when your start to anthropomorphise your jeep into somthing above a dog and below a hooker
ziebartrob is offline
post #6 of 15 Old 11-12-2010, 11:53 AM
Doch80
I took mine to the locksmith (pop-a-lock) and they can recreate one from your vin.
Doch80 is offline
post #7 of 15 Old 11-12-2010, 12:09 PM
Destr0
And when you have one made, make copies of it. :-)
My wife has a set of keys to both my Jeeps even though she refuses to drive them. Came in handy when I lost my keys on the paintball field. :-) Someone found them later in the day, but stuff I needed was in the Jeep (I own the PB company, not just a player).
~K
Destr0 is offline
post #8 of 15 Old 11-13-2010, 06:01 PM Thread Starter
hurricane99
thanks guys for the comments i really would like to save the ignition because it was replaced by the last owner b/c it was wornout so its new i will try the dealership in chattanooga and see what they say. if they cannot cut it can i take the door to a locksmith and get it from the door lock? either way when i do get a key im making like 4 copies of it just in case
post #9 of 15 Old 11-13-2010, 07:21 PM
Doch80
Just take the jeep to the locksmith. He can't make one from the door but he can make one from your VIN... that's what they told me anyways. I had thought the same thing... and I have heard them making a key from the door... I guess the place I went couldn't.
Doch80 is offline
post #10 of 15 Old 11-13-2010, 07:22 PM
Doch80
scratch that, I'm a moron... no key, no taking the jeep to the locksmith.... they can still make one from your VIN. Just have to take it home to make sure it works.
Doch80 is offline
post #11 of 15 Old 11-13-2010, 09:58 PM Thread Starter
hurricane99
thanks dosh i will get the vin tomarrow and go to a locksmith and see what they can do.
post #12 of 15 Old 11-13-2010, 10:00 PM
Ripper3494
idk bout you guys but i start mine with a pocket knife
Ripper3494 is offline
post #13 of 15 Old 11-13-2010, 10:02 PM
93jeepyj
you could pull the lock cyl out of one of the doors and take it to the locksmith.
93jeepyj is offline
post #14 of 15 Old 11-13-2010, 11:11 PM
04WJny
1987 YJ Wrangler
you could also replace the lock cylinder its $22 because i dont know how much a locksmith would charge.
http://www.quadratec.com/products/55216_05.htm
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #15 of 15 Old 11-14-2010, 07:35 AM
93jeepyj
Original Replacement Parts 83501971 - Ignition Switch and Keys for 85-89 Jeep® CJ-7, CJ-8 Scrambler & Wrangler YJ - Quadratec
Probably not a bad idea and if its already been done before the key you just paid to have made from the vin probably wont work anyways. had that problem with a 92 s10.
93jeepyj is offline
TJ lost power to the ignition and blows 30a fuse? gtxracer TJ Wrangler Technical Forum 0 05-27-2010 02:24 PM
ignition randomly turns on after jeep is turned off and ignition locked karthac YJ Wrangler Technical Forum 3 01-12-2010 08:35 PM
Epic Ignition Battle (replaced everything but the ignition switch!) thechadwick YJ Wrangler Technical Forum 10 08-27-2009 11:02 PM
Questions about ignition wires and other ignition stuff Fernando YJ Wrangler Technical Forum 10 08-11-2009 05:33 PM
Lost my vibes, but I also lost 2nd gear?? pookie TJ Wrangler Technical Forum 14 01-23-2006 09:34 PM
