lost 2 wheel high and 4 wheel high - JeepForum.com
post #1 of 10 Old 03-01-2009, 08:29 PM Thread Starter
FraziersYJ
I can't figure this out.... goin down the road, and all of a sudden it was like i put it in neutral, but the tranny's fine, so my next thought was the transfer case popped out of gear so i pulled it into 4 wheel high n nothing happened, i pulled it into low and it goes like there is nothing wrong with it. But now when i try to put it in high it's always low no matter where the shifter is, all the way forward or all the way back. anybody else ever heard of this happening?
FraziersYJ is offline
post #2 of 10 Old 03-01-2009, 08:39 PM
shaggyjim
Drain the TC and check for chunks.
Jim...
"That's more fun than watching a hippie get mauled by a bear!"
shaggyjim is offline
post #3 of 10 Old 03-01-2009, 09:10 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
x2. Sounds like your high range gear stripped out.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #4 of 10 Old 03-01-2009, 09:19 PM
Grape Ape
Web Wanker
Grape Ape's Avatar
If it shifts out of 4 low but you have no other gears then there is something wrong with the insides of the t-case. Sheared gears etc.
If it will not shift out of 4 low (stays in 4 low regardless of what you do) then I would check the linkages. It sounds like a linkage came loose and allowed the t-case to drop out of gear, you then pulled it back to 4 low and the linkage connection to go forward back into 4 high and 2 high is disconnected.
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline
post #5 of 10 Old 03-01-2009, 10:16 PM
Burnerman
Burnerman's Avatar
What Grape said. The end of the linkage rod has a flanged stop on it so when you pulled it to low it slid against the stop and went to lo. When you move it forward the adjuster just slid on the shaft and did nothing. Crawl under and check it out....
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #6 of 10 Old 03-02-2009, 11:23 AM
MrLude1
Not to hijack your tread, but I'm havin a similar yet opposite problem. I can't even shift into 4Wlo, could it also be a TC issue?
Brian's Jeepin'
MrLude1 is offline
post #7 of 10 Old 03-02-2009, 11:32 AM
cmsurfer
As in physically can't shift into 4 Low? Can you shift into 4 High or neutral? When I first got my Jeep, it took me and other person to physically shift into 4 low. It may have never been used, but it's been fine since. Just so you know, you have to push the shifter to the right then pull back to 4 low.
cmsurfer is offline
post #8 of 10 Old 03-02-2009, 11:39 AM
MrLude1
Thanks for the quick response, but, yeah, I physically cannot shift the darn lever into 4wlo. I know (shift-knob illustration) to shift to the right then down into 4Wlo, but no luck. I bet it's never been in that range in my case either tho.
Brian's Jeepin'
MrLude1 is offline
post #9 of 10 Old 03-02-2009, 02:46 PM
SECorBust
When I tore down my t-case (just for good measure) one of the shift forks was gnawed up like the dog ate it. It still shifted, but I replaced the part. I have heard of others who needed new shift forks. There are some plastic parts that go on the end of the forks and once those fall off or get worn down who knows what happens.
SECorBust is offline
post #10 of 10 Old 03-02-2009, 03:04 PM
CaveDave
Y J? Because...
CaveDave's Avatar
The shifter rotates a bracket within the Tcase with several indentions on it, one for each gear, 2hi, 4hi, etc. To hold this bracket in place there are two spring loaded pins. One is for your vacuum switch, the other is opposite the switch. One or both of these may have failed - leaving this shifter bracket loose and unstable. Unfortunately, the Tcase must be disassembled to inspect one of these spring loaded pins (the one opposite the switch).
If you didn't hear a bunch of grinding then the likelyhood of failed gears is very low.
CaveDave is offline
Do wheel spacers make your steering wheel wobble at high speeds? bgndobe TJ Wrangler Technical Forum 22 07-20-2009 08:27 AM
4 WHeel High bella mia YJ Wrangler Technical Forum 0 04-27-2009 11:00 AM
Play in wheel at high speed Benny2Times TJ Wrangler Technical Forum 6 08-06-2008 07:06 PM
4 wheel high hopping? coppa TJ Wrangler Technical Forum 8 03-25-2005 12:16 PM
4 wheel high not working illinijeepster YJ Wrangler Technical Forum 5 02-12-2005 05:22 PM
