Loss of Power during warmup - JeepForum.com
post #1 of 2 Old 07-21-2004, 10:49 AM Thread Starter
eringrotta
My '95-96 4.0L runs extremely poor during the first five minutes of warm up, and runs perfectly after that. I hooked it up to a Snap-On computer while it was running poorly and the computer showed no codes. Has anyone had any experiences like this?
This is a '95 or '96 4.0L out of a Grand Cherokee that I swapped into my '84 CJ. It ran great at first, and now this.
Any help is appreciated.
eringrotta is offline
post #2 of 2 Old 07-21-2004, 07:05 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
You might want to double-check with the folks in the Engine's Section ..
I would start with a compression test on all the cylinders to make sure that they are all functioning properly (test cold, re-test hot)
The next thing I would check is the power coming out of the coil and all the connections around it.
Next I would check the injectors - are they clean? Is the fuel regulator on the return line to the tank working properly.
Do you have a worn throttle-body, or a vacuum leak?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
Still loss of power Iamjr TJ Wrangler Technical Forum 9 01-14-2010 07:32 PM
loss of power? silverbullet09 TJ Wrangler Technical Forum 5 08-27-2009 05:01 AM
power loss dw9301998 YJ Wrangler Technical Forum 7 07-11-2009 10:03 PM
Help with Power Loss Chisow TJ Wrangler Technical Forum 4 04-12-2009 07:08 PM
Loss of power? 1998TJI6 TJ Wrangler Technical Forum 2 01-05-2009 10:09 AM
