Loss of Power - JeepForum.com
post #1 of 8 Old 03-27-2013, 10:15 AM Thread Starter
bashbro
Loss of Power
1989 YJ ... 2.5L, 117,xxxx miles ... Brand new fuel pump. Jeep unforutnately only gets driven every couple months. Noticed this problem the last time i had it out and again this past weekend. Jeep always starts up initially and runs well. After a few minutes of running though, the jeep loses power. You press on the gas and the RPM's increase a little than die down immediately. You cannot feather the gas at all, as it just keeps dying. Upfront i can hear a hissing type sound, also have a smell when this happens. Smells is not burning per say, but more of a strong exhaust type smell. After this happens, if i turn the key off and shut the motor down, as soon as i turn the key and run the motor again the problem is gone. I get full power again upon restarting. Anyone have any ideas where to start with this? Thanks
bashbro is offline
post #2 of 8 Old 03-27-2013, 10:20 AM
Rproject
1987 YJ Wrangler
An '89, so it's carburetoreted - yes? Sounds like it's out of adjustment. My '87 had a similar smell. Adjusted the Carter POS and it runs like a champ. Thing is, I have to readjust it every month or two because the idle mixture screws work their way loose. CAN'T WAIT until Uncle Sam gives me my money back so I can get the Motorcraft 2150!
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #3 of 8 Old 03-27-2013, 12:39 PM Thread Starter
bashbro
No carb. It is fuel injected.
bashbro is offline
post #4 of 8 Old 03-27-2013, 08:27 PM
jokerchief462
Vacuum or exhaust leak. Both play he'll with O2 sensor readings back to ECU which adjusts the mixture if fuel to air. So it becomes a performance problem. Find and repair the hissing sound and see what that does. The TBI is usually really dependable.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #5 of 8 Old 03-28-2013, 05:43 AM
Siva283
Check your vacuum lines too. I have learned the even a pinched line can cause issues like this. So not only check for leaks but check for a pinched line also. I know I am MPFI and you are TBI but alot of the troubleshooting is the same. Particularly check the map sensor vacuum line. The TPS uses it as a reference. For example When I replaced my enfine i broke a ccv vacuum line. I capped it off temporariliy and it threw a TPS code. Once I fixed the line no more code.
Ask me how I know...
Siva283 is offline
post #6 of 8 Old 03-28-2013, 06:17 AM
DEERSLAYER94YJ
Catalytic Converter could be clogged up, might be a reason for your power loss?
Nightcrew Member #093
DEER--- It's whats for supper!!
DEERSLAYER94YJ is offline
post #7 of 8 Old 03-28-2013, 09:18 AM
Que89YJ
Check your egr and egr pipe on the exhaust manifold. You are going to need to loacate the source of the noise and it is a likely canidate.
Que89YJ is offline
post #8 of 8 Old 03-28-2013, 11:00 AM
Siva283
Thats why I was thinking vacuum lines. I had one collapse and crack that made a surprisingly loud whistling noise. I never thought about egr. I guess because I am lucky enough to not have one.
Siva283 is offline
