At a loss need help please yj cutting out - Page 3 - JeepForum.com
post #31 of 38 Old 03-21-2013, 08:03 PM Thread Starter
Renegade85
Alrighty didn't figure any suggestions
Renegade85 is offline
post #32 of 38 Old 03-21-2013, 08:22 PM
89yj901
Have you replaced your ignition control module it can cause a rough ride and make sure all your plugs are snapped on tight
89yj901 is offline
post #33 of 38 Old 03-21-2013, 10:23 PM
youngjeepr
Does it matter what temp the engine is at? After it dies it fires right back up? What fuel milage are you getting?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #34 of 38 Old 03-21-2013, 11:35 PM
squishy
CEL on? Pull codes? TPS off the top of my head.
squishy is offline
post #35 of 38 Old 03-22-2013, 06:32 AM Thread Starter
Renegade85
I've ordered a tps it'll be here Saturday but I took it to the shop they had it for two days couldn't figure it out they couldn't get it to show codes and to answer the other question it'll turn over fire then die instantly it'll do that about two or three key turns then will idle really high then idle normal...and fuel mileage sucks
post #36 of 38 Old 03-22-2013, 08:59 AM
youngjeepr
Have you checked for a leaky injector?
post #37 of 38 Old 03-22-2013, 10:44 AM Thread Starter
Renegade85
Yep
post #38 of 38 Old 03-23-2013, 02:48 PM
Blackfish
Instead of a bad component look for a cross connection between the, when components heat up they expand this will cause slight disconnect, look at the throttle body sensors since you're ecu is compensating for fuel when it come back on, also check the ground on the back of the motor to make sure the strip at the map sensor isn't broken, I will say that what your describing sounds like what I had with a bad o2 sensor.
My boss made the comment that "I bet you missed me over the holiday break",my response was "yes your right I did, but my aim is getting better"
Blackfish is offline
Cutting out , ignition problem , missing , YJ
