Losing Power while driving - Page 2 - JeepForum.com
post #16 of 36 Old 04-10-2013, 04:26 PM
Chrisnvegas
Chrisnvegas's Avatar
Originally Posted by Que89YJ View Post
The nutter would not pass smog if modified. It is basically taking back the ignition system to the early CJ ignition system. The nutter on the other hand is a good mod and necessary if you put on anything other then the stock carb and is probably the #1 mod on the 4.2.
I was pushing him toward keeping the carb stock because of the Californians (Not all mind you) who have come here and tried to turn this place into where they left. It is actually illegal to sell a non compliant vehicle here unless sold as a "tow away" It can open a real can of worms!
I live on the far west side of town and for what ever reason, I don't have to test??
Ban computer updates, auto-play video and music without real instruments.
Chrisnvegas is online now
post #17 of 36 Old 04-10-2013, 04:54 PM
Que89YJ
yeah, the testing in michigan was the same way. County by county you had one county requiring it and another not. They got rid of it here. That is a big difference in deciding what you need to do.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #18 of 36 Old 04-10-2013, 04:56 PM Thread Starter
ad-man
1989 XJ Cherokee
Yeah, i was typing thinking of just leaving the hoses in there so if i did have to go to another smog shop they would see it still hooked up. I will worry about the mod when i sell it. Which if i get it running right wont before a long time. I could see me keeping this for 15 to 20 year and by then it might not be subject to a check. I just checked the dmv site and if i reg it as a classic i wont have to smog it but i cant drive it more than 2500 miles a year. I think i will burn through that pretty quick.
Another good thing about reading that 16 page thread is i think i found what is wrong with my 4x4 drive not kicking in. I am real sure it doesn't have the vac line hooked up. So i am getting closer.
Whoo hoo!
ad-man is offline
post #19 of 36 Old 04-10-2013, 05:28 PM
Chrisnvegas
Cleaning the idle tubes is still the easiest repair.
Re read and just Doooo ittttt! You will be back good as new!
Will take 30 minutes. Do you have a garage and tools?
post #20 of 36 Old 04-11-2013, 07:13 AM Thread Starter
ad-man
1989 XJ Cherokee
So i didnt get time to do it last night. But i did look at it.
So from this pic, i am looking to clean out the copper tubes? I circled them in red but i am not sure if you can see it.
Anyway, i need to remove the hoop that the cleaner bolts to. Then pull the linkage off of both ends of the top plate. Take the 2 screws off the plate and pull it. That is the choke plate, right? Then i can pull the screw on the left side of the rod and pull it out to the right. Then i pull the 2 screws below that and the whole venture will come out?
Then clean the tubes and reverse to install?
ad-man is offline
post #21 of 36 Old 04-11-2013, 07:57 AM
Que89YJ
Adman your profile says you are 93 years old! You seem to be doing pretty good old timer!
I dont know very much about carbs but try this link and see if it helps:
http://www.jeepforum.com/forum/f12/1...e-luck-959564/
Que89YJ is offline
post #22 of 36 Old 04-11-2013, 10:20 AM Thread Starter
ad-man
1989 XJ Cherokee
Thanks Q. Definitely not where i thought they were. Pictures help so much!. A few more parts than i thought to come off, but still seems do able. Now if i can just get the time. Between the hobbies, chores, work and chasing tail i have to find some extra time.
Nope not 93, just about half of that. I never put to much real info on the net. I dont trust big brother, so i make them work for it if they want to follow me around.
ad-man is offline
post #23 of 36 Old 04-11-2013, 10:43 AM
Que89YJ
Chris does have a point. I still think it's strange you were running good and got it smogged and then it craps out on you. Are yousure they didn't tweak anything when you took it to them?
Que89YJ is offline
post #24 of 36 Old 04-11-2013, 12:24 PM Thread Starter
ad-man
1989 XJ Cherokee
I had not really pushed it hard before then. Steering is a little squirrelly so i had not had it on the freeway before. I think its was more to do with bouncing it around off road really. When we first got back to pavement, i thought the exhaust sounded funny and that is when it started stalling at the stop signs. Not sure how much junk is in the gas tank. Something could have come loose and got in the fuel line pretty easy. Plus its sounding like this happens alot. So i am going to check it out. Also going to check to see if the carb might have come loose and has a vac leak then the fuel filter. But with a clogged filter i would think that it would not start at all. Its taking a while to start now.
ad-man is offline
post #25 of 36 Old 04-11-2013, 01:07 PM
Que89YJ
No it can partially block the flow. I am not a 4.2 guy so I am not as familar. Old4x and Pete know them real well. My strong suit is electrical.
Que89YJ is offline
post #26 of 36 Old 04-11-2013, 04:56 PM Thread Starter
ad-man
1989 XJ Cherokee
Well i finally did it. Cancelled some plans to do this today and Chris was right. Less than 30 minutes. Didn't seem clogged but there was some yellow jelly on the tip of one. But she fired right up and idles smooth. I don't think i am going to get it on the highway today but maybe this weekend.
Thank you all for your help.
All i can say is wow, that was way easy!!
ad-man is offline
post #27 of 36 Old 04-11-2013, 05:00 PM
Chrisnvegas
Excellent!
Good Job!
post #28 of 36 Old 04-11-2013, 05:02 PM
Que89YJ
good call chris!
Fault codes:
No Start:
Que89YJ is offline
post #29 of 36 Old 04-11-2013, 05:17 PM Thread Starter
ad-man
1989 XJ Cherokee
I owe it all to you two and everyone on this site.
Thanks.
I would never bad a clue where to start without the advise from here
ad-man is offline
post #30 of 36 Old 06-17-2013, 05:23 PM Thread Starter
ad-man
1989 XJ Cherokee
OK so I got back to working on this thing.
ad-man is offline
