loosing power, fuel problem? - JeepForum.com
post #1 of 10 Old 04-10-2013, 05:45 PM Thread Starter
1993moneypit
i have a 1993 wrangler yj with the 4.0 inline 6. i got it right around thanksgiving and have been having trouble with it ever since. the guy before me said he had just rebuilt the motor, i have decided this was total BS. it started having major problems with loosing power and was making wierd noises. being at college i didnt have all my tools so i took it to a shop to get an idea of what could be wrong and they said that it was a fuel problem and it needed a new fuel pump and the fuel rail cleaned. so i dropped the fuel tank and changed out the fuel pump, then i changed the fuel filter and cleaned the fuel rail. the problem got a lot better but was not completely right. i would drive it for about 10 to 15 miles and it starts cutting out and will eventually shut off, but i can start it back up and it will do the same thing all over again. so i changed the fuel regulator and cleanded the throttle body. got a little better but still is doing the samething. i am lost on what else it could be, anyone have any ideas?
1993moneypit is offline
post #2 of 10 Old 04-10-2013, 06:28 PM
minerbob
2014 JK Wrangler
Crankshaft position sensor bad?
minerbob is offline
post #3 of 10 Old 04-10-2013, 06:36 PM Thread Starter
1993moneypit
not sure i havent checked that, do know where that would be located? the only other thing i can think of is i didnt change the pick up screen on the bottem of the fuel pump inside the tank. could that be the whole problem
post #4 of 10 Old 04-10-2013, 06:41 PM
Chrisnvegas
INFIDEL
Chrisnvegas's Avatar
I have had multiple problems with aftermarket fuel pumps. Got tired of pulling fuel tanks twice in the same month. New fuel pumps can crap out within a couple weeks without a new fuel filter and screen.
I now only use original equipment fuel pumps. They cost more but I only have to do them once.
I hate computer updates
Chrisnvegas is offline
post #5 of 10 Old 04-10-2013, 06:55 PM Thread Starter
1993moneypit
the fuel pump as only been installed for 4 days and it didnt fix the problem just seemed to make it a little better.
post #6 of 10 Old 04-10-2013, 07:09 PM
Mark05059
you sure its a fuel problem and not a clogged cat?
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #7 of 10 Old 04-10-2013, 07:23 PM Thread Starter
1993moneypit
at this point idk what it could be lol. it dosnt have a cat though just a magnaflow muffler
post #8 of 10 Old 04-11-2013, 10:40 AM
minerbob
2014 JK Wrangler
When the CPS gave up on my '94 4.0 several years ago, it behaved the same way. It would restart when it cooled off and die after 10 or 15 minutes of running. Should show a code. I believe it is on the front of the engine.
minerbob is offline
post #9 of 10 Old 04-11-2013, 11:59 AM
Que89YJ
Check your codes:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
The crank postion sensor is on the rear of the blok at the top of the bell housing. It is a common issue with stalls. It doesn't always set a fault code.
Look at this search for a pic:
http://www.google.com/search?q=site:...w=1584&bih=625
Que89YJ is offline
post #10 of 10 Old 04-11-2013, 09:33 PM
Boanerges
Originally Posted by Que89YJ View Post
Check your codes:
Yes the CPS is on back of bell housing. Also before you plug the new one in, take a pair of pliers and gently squeeze the receiving end of the plug (female end) to make the little metal connectors inside fit the pins a little tighter. I chased an electrical issue with new cps for about 2 months before doing this and haven't had a problem with lost signal since. If it loses signal, it loses spark which causes drop offs and cut outs.
Junior, you want Some'n? Hushpuppies Daddy! We got no time for dat Crap! Dumb Sumb!+@#
Boanerges is offline
fuel , problem , wrangler , YJ
