Loosening Lug Nuts - JeepForum.com
post #1 of 6 Old 09-08-2013, 09:27 PM Thread Starter
szbaren3411
Loosening Lug Nuts
Finished putting on a 2.5" suspension lift last week. Took her for a test spin directly afterwards and the lug nuts on the rear driver side started to come loose. Tightened them up and Everything was good to go. Drove another twenty miles and they had all come loose again. I'm at a loss here and yes the tapered side is in.
szbaren3411 is offline
post #2 of 6 Old 09-08-2013, 09:30 PM
JeepinJeremy
It's called a torque wrench buy one. Tighten the bolts in a star pattern job done. If they keep coming loose you do not have your rear drums seated all the way and you most likely warped a drum at this point.
JeepinJeremy is offline
post #3 of 6 Old 09-09-2013, 04:03 AM
Que89YJ
I bet someone greased them. Clean the studs and torque them down.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #4 of 6 Old 01-23-2014, 05:46 PM Thread Starter
szbaren3411
I'm really sad to admit this; I had only used a 12' ratchet to tighten them down. I broke out a true tire iron and its a non issue now.
post #5 of 6 Old 01-23-2014, 06:51 PM
Que89YJ
Lol you better be able to get them off again.
Fault codes:
No Start:
Que89YJ is offline
post #6 of 6 Old 01-23-2014, 07:08 PM
MikeHoncho88
2015 JK Wrangler
Lug centric wheels? Did you torque the lugs down before lowering the vehicle off the jack? Very common mistake and is guaranteed to make the lugs loosen as you drive.
“Race fans, I had inferred from my one trip to the Brickyard 400, fell into one of two categories: tattooed, shirtless, sewer-mouthed drunks, and their husbands.” - Steve Ruchin
MikeHoncho88 is offline
