Loose Trans Mount Bolt - Page 2 - JeepForum.com
post #16 of 16 Old 04-12-2010, 01:07 AM
BlackRhino
BlackRhino's Avatar
I believe that the trans mount for the AX-15 is further back than the AX-5, you can see the bolts that are recessed into the skid plate in the OP's first pic.
Black '91 YJ, pretty much stock for now. Finished engine rebuild. Runs beautifully.
BlackRhino is offline
Trans mount bolt bent blackruby56 TJ Wrangler Technical Forum 0 09-09-2009 10:01 PM
trans mount bolt broken hilton00 TJ Wrangler Technical Forum 2 08-04-2009 04:18 PM
Big Bolt Problem, need to know trans to motor bolt size FAST!!!!! antec YJ Wrangler Technical Forum 5 06-05-2009 12:39 PM
trans mount bolt %*$@!#!!!! southernss TJ Wrangler Technical Forum 4 05-14-2009 12:39 PM
Leaking Trans, Loose Shifter mikenj73 YJ Wrangler Technical Forum 1 08-22-2004 12:18 PM
