loose steering wheel - JeepForum.com
post #1 of 9 Old 09-17-2011, 03:06 PM Thread Starter
TheNewbie
My wife's boss has an 88 YJ. We were talking Jeep at the last company party and he said that he has a problem with his steering wheel. It will wiggle back and forth and he said that it will steer itself while he's going down the road.
My first thought was that it was his 1" lift shackles. But he said that it will wiggle even when it's parked. It's a tilt column if that makes any difference. Is there anything that might have come loose in there? And if so how should he go about fixing it?
I told him I'd post here on JF and see if anyone could help him out. Thanks...
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #2 of 9 Old 09-17-2011, 03:14 PM
sbsg2005
There are 3 screws behind the turn signal cam that are prone to coming loose, when they come loose the column will feel sloppy .
sbsg2005 is offline
post #3 of 9 Old 09-17-2011, 03:20 PM Thread Starter
TheNewbie
How do you get to them? I'm not sure what the turn signal cam is to be honest.
post #4 of 9 Old 09-17-2011, 04:48 PM
Ronnie-Evans
Good ol loose colum. Common issue. Tighten those bolts up and you should be fine.
I think most of us can all agree on Jeeps, zombies, bacon, beer, and big boobies.
Ronnie-Evans is offline
post #5 of 9 Old 09-17-2011, 05:07 PM Thread Starter
TheNewbie
So just pull the horn cap off and look for 3 screws/bolts to tighten?
post #6 of 9 Old 09-17-2011, 07:08 PM
sbsg2005
Its a little more involved than this. First you have to remove the steering wheel, then the lock plate then behind that is the turn signal cam( its a big white plastic assembly) this has to be removed then behind that is the 3 screws some are phillips some are torx tighten these up and it should solve the problem. Pay real close attention to how things come apart there are a lot little parts in there and they need to go back in exactly how they came out otherwise the turn signals wont cancel on their own and the wheel will remain floppy.
sbsg2005 is offline
post #7 of 9 Old 09-17-2011, 08:38 PM
srdart67
First thing I would do is check the steering gear box. Mine has about 2 inches of play when parked and off and I can watch the shaft move but the pitman arm doesn't. Also check out where the gear box mounts to the frame. might be some problems there.
srdart67 is offline
post #8 of 9 Old 09-17-2011, 09:06 PM
ejeeperguy
1982 CJ7
don't tell him how to fix it until the wife is up for a raise then .... hit him up hard for the info.
ejeeperguy is offline
post #9 of 9 Old 09-18-2011, 12:37 PM Thread Starter
TheNewbie
They treat her pretty well. I think I'll go ahead and give up my ace in the hole this time
Thanks for the info guys. I'll pass it along.
Steering got loose... Play in steering wheel. AnonymousD YJ Wrangler Technical Forum 4 11-27-2010 07:22 AM
Steering Problem Loose Steering Wheel fallenbirdbeak YJ Wrangler Technical Forum 4 04-10-2010 01:00 PM
loose steering wheel kenandtj TJ Wrangler Technical Forum 6 06-10-2007 12:52 PM
Loose steering wheel Jay90YJ YJ Wrangler Technical Forum 1 07-04-2005 09:43 PM
Can anyone help me with loose steering wheel ROYALT91 YJ Wrangler Technical Forum 4 02-03-2005 07:55 PM
