Loose Steering Column - JeepForum.com
post #1 of 15 Old 01-23-2006, 12:26 AM Thread Starter
Fenix85182
Fenix85182's Avatar
I've had this issue since I got my Jeep. It's the 89 Laredo, so it's got the tilt-wheel. I've got the tilt-wheel set where I like it. Though, if I push the sterring wheel at the top or sides, the entire steering columns moves a few degrees in that direction. I've gotten used to driving it like this, though I know it's not safe. Do you guys know if there is some sort of small universal joint on the passenger side of the firewall that could be causing this? Anyone else experienced this problem?
2005 Jeep Wrangler TJ Sport
2009 Honda Accord EX
2008 Honda CBR600RR Graffiti Edition
Fenix85182 is offline
post #2 of 15 Old 01-23-2006, 07:55 AM
Bad_Dog
Just had that fixed in my Jeep this past week. Had to have it done in order to pass state inspection. (sigh)
It involves taking the steering column apart - removing the steering wheel, turn signal arm, ignition cylinder, etc. etc. Buddy of mine did it (he's a mechanic for a local Chevy dealership) and took him a little over an hour from start to finish. There are four bolts that had to be tightened, but like I said, you have to tear down the steering column all the way down to where the tilt 'elbow' is. Ug. Not pretty.
Here's a URL to a how-to, but no pics. I can't find the URL that I once had that had step-by-step how to with pics, sorry. http://www.ifsja.org/tech/steering/column.shtml
Do a search on steering wheel tilt and you should find a lot of posts about this problem, fairly common.
OlllllO 2013 Wrangler Sahara Unlimited
[]lllll[] 1991 Wrangler Renegade, 4.0L Auto (Retired 2013)
Bad_Dog is offline
post #3 of 15 Old 01-23-2006, 01:52 PM Thread Starter
Fenix85182
Fenix85182's Avatar
Thanks! That's a huge help, even without pics. I had begun taking this apart a few months ago, but I could tell it was going to be more in depth than I was ready for. I'm just happy I have a solution now.
post #4 of 15 Old 10-24-2010, 08:37 PM
cmd4rge
Has anyone figured out a good fix for this problem. I've been digging around on the web and haven't found a clear solution. Please help! this is driving me nuts.
cmd4rge is offline
post #5 of 15 Old 10-24-2010, 08:45 PM
Hbeaudreau
1987 YJ Wrangler
It is the 3 or 4 torx bolts in the steering column. Me and my neighbor both had to do this to out trucks. it happened to my jeep and to his old chevy 1500 with the same steering column. It's a pain. You need lots of tools and some time. Took me forever to get through it and everything back together the first time. I ended up having to open it up a few more times within the month to fix a few other items in their. Now im a pro. In and out of the steering column in under an hour. Good luck! ill see if i can find the page i used to help guide me through and post it up
So what if my Yj is 5 years older then I am?
63 Scout 80 - 196 L4, 32 KM1's, SOA
87 YJ- 4.2TBI, Dana 44's, 35 KM2's, SOA
YJ Build : http://www.jeepforum.com/forum/f12/my-87-yj-build-thread-1072026/
Hbeaudreau is offline
post #6 of 15 Old 10-24-2010, 08:53 PM
guy.griffin
guy.griffin's Avatar
1997 XJ Cherokee
Mine was lose when I bought it. I had the whole column apart to to change the turn signal switch. I tightened one of the bolts it was good but now its loosening up again I think I will have to put some lock tight on the bolts
Also I think it might have to do with people using their steering wheel to pull them self's in the jeep that's why they loosen up
guy.griffin is offline
post #7 of 15 Old 10-25-2010, 12:20 AM
Hbeaudreau
1987 YJ Wrangler
Well im pretty sure there is more then one bolt in there and yes use lock tite
post #8 of 15 Old 10-25-2010, 07:16 AM
LoggingRoads
Are you guys talking about the 'entire' steering column being loose (down through the firewall), or just the tilt part?
Mine is a little loose and floppy at the tilt joint, but it doesn't really feel unsafe in as far as being able to steer.. The steering feels nice and tight..
Didn't think it was anything to worry about..
LoggingRoads is offline
post #9 of 15 Old 10-25-2010, 08:47 AM
cmd4rge
I'm talking about just the tilt part. It's probably just the release lever being extra loose. My issue is when ever it hit a big bump, the level disengages and the tilt steering assembly comes loose. Other than that, my steering is a tight as my ex-wife.
This seems to be a problem with many of the TJ's, but I've just been able to find a fix other than bubble gum, duct tape, or a shoe lace.
cmd4rge is offline
post #10 of 15 Old 10-31-2010, 10:16 AM Thread Starter
Fenix85182
Fenix85182's Avatar
Wow, I thought this thread disappeared 4 years ago!
I remember finding some diagram online on how to disassemble the steering column of a CJ-7, which was identical to that of the YJ. For me, it was the 4 torx bolts holding the column onto the firewall, not the entire assembly down to the box. As someone posted, take your time. I used a steering wheel puller to get the wheel off. From there it's basic disassembly, just time-consuming.
post #11 of 15 Old 10-31-2010, 02:07 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Sure this may have been an old thread, but the problem is common enough. Try these:
Tilt Column Fix - Dale's Jeep Junk
Inside the GM tilt steering column - Pennock's Fiero Forum Yes, Fiero, but it's a GM tilt column, remember?
Good luck with this, it isn't a tough job, just meticulous. Really helps to have a puller and a lockplate spring compressor. I made my own............this thread was my very first post to Jeepforum-- http://www.jeepforum.com/forum/f12/l...ressor-508587/
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #12 of 15 Old 03-29-2015, 09:31 PM
dmdenny
I am about to replace my column on my 89 YJ. At 65 to 68 I get a nasty vibration and cannot figure out where it is coming from. I have replaced the suspension and steering shock. It isnt a DW, its a vibration. I am hoping the column replacement fixes it. Any insight would be much appreciated.
dmdenny is offline
post #13 of 15 Old 03-29-2015, 10:22 PM
timatoe
timatoe's Avatar
Can't imagine a bad column is causing a vibe you feel as certain speeds.
What condition are your tires in? When was the last time they were balanced?
timatoe is offline
post #14 of 15 Old 03-29-2015, 11:08 PM
Bigmaaty
1979 CJ7
I second Opihi59's links. Dales got me through the work on mi '89 XJ, very helpful. Get it done, it will only get worse. The removal tool for the snap ring on the shaft can be bought or borrowed from your local auto parts store. Well worth it, IMHO. I have done it both ways, several times now on multiple vehicles. That tool makes the frustration level much lower. Be careful with your wiring on re-install. The first time I did this I pinched one and grounded it out when I put it back together. Unfortunately you don't find this out until you are all done putting it together. It has been awhile since I did it but I believe it takes a E8 external tooth socket to tighten the bolts in question. Definitely use Loctite, cheap insurance.
Bigmaaty is offline
post #15 of 15 Old 04-01-2015, 02:45 PM
dmdenny
timatoe, thanks for the reply. tires are new. 33x12.5 on older centerline wheels. My thought was having a high speed balance done on all four and rotate them. The column has to be replaced as its dead and cant be repaired. I know the vibration is a result of something and it seems the usual suspects are balance, track bar and u joints. track bar and u joints are good. balance is the question. I hope it solves the issue.
dmdenny is offline
loose steering column lever dkBOVICE TJ Wrangler Technical Forum 10 10-24-2010 08:40 PM
88 steering column very loose jesseheaton152 YJ Wrangler Technical Forum 15 11-18-2009 08:48 PM
loose steering column jmenegazzo YJ Wrangler Technical Forum 3 02-05-2009 11:51 PM
steering wheel/column loose jeepinMatt YJ Wrangler Technical Forum 4 04-14-2008 08:49 PM
loose steering column y(j)me YJ Wrangler Technical Forum 4 11-17-2002 03:30 PM
