LOOSE SOFT TOP - JeepForum.com
post #1 of 3 Old 05-12-2002, 07:14 PM Thread Starter
ErikJordan
Pimp Hand
ErikJordan's Avatar
LOOSE SOFT TOP
does any body have any suggestions on how to tighten up this soft top? this thing is flappping in the breeze.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #2 of 3 Old 05-12-2002, 07:23 PM
JonC
The best thing I can suggest without seeing what you're working with is to make sure you have all the frame parts you're supposed to have and they are all installed correctly. When I got mine from the previous owner, one of the rear spreaders was broken and the frame was not putting the right tension on the canvas. The part was $40 at the dealer, but about $11 from JC Whitney... guess where I got mine!? Make sure everything is installed correctly also - fully erect, so to speak. 8^)
Good luck
PS... it's summer and you're in California, take the top OFF and worry about it in the fall!
Black '91 Wrangler
JonC is offline
post #3 of 3 Old 05-13-2002, 08:01 AM
SnowMan
I went and bought some black foam from the local craft store and stuffed it inbetween the back support pole and the top (back left and right corners) and now there is no smacking from the rear windows, as for the front, I don't drive on the highway with one window down, they both have to be down or not at all to equal the flow I guess.
Is that you John Wayne, is this me!
SnowMan is offline
Loose Soft Top TJSahara98 TJ Wrangler Technical Forum 8 07-09-2008 07:51 PM
soft top really loose 97tjtom TJ Wrangler Technical Forum 6 03-19-2008 10:30 AM
Loose Soft Top VICTIM_OF_PAIN TJ Wrangler Technical Forum 5 07-11-2006 01:23 PM
Soft top Loose FOoLieo TJ Wrangler Technical Forum 4 09-09-2005 03:54 PM
loose soft top USFJeeper TJ Wrangler Technical Forum 2 10-19-2004 12:32 PM
