loose shift linkage - JeepForum.com
post #1 of 4 Old 08-17-2012, 06:25 AM Thread Starter
chuck172
loose shift linkage
Besides adjusting the trunion on a wrangler yj auto trans., is there any way to tighten up a sloppy gear indicator? I think the problem (looseness) is internal?
chuck172 is offline
post #2 of 4 Old 08-17-2012, 11:24 AM
blake989
Are you having problems with the indicator on the column, or actually shifting? If it's not shifting as selected, the only other place you should check is the actual selector on the transmission. Follow the linkage, the selector is on top of the tranny on the driver's side. The selector is a post that sticks up out of the transmission, the linkage rod spins that post to select gears. The post itself is round with a flat spot on one side, the shift rod connector slips over that post with a corresponding pattern that aligns with that flat spot. The pattern on the thing that slips over the post could be worn out.
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
post #3 of 4 Old 08-17-2012, 05:58 PM Thread Starter
chuck172
I'll check out that connector that slides over the post, thanks.
chuck172 is offline
post #4 of 4 Old 03-28-2013, 04:41 AM Thread Starter
chuck172
I got my trans serviced and asked if the loose linkage can be fixed. I was told that a part needs replacing in the trans. It would cost aprox. $200.00. Best bet would be to live with it.
I sure would like to fix this. Anyone else have this problem?
chuck172 is offline
shift linkage 02TJ-clayton TJ Wrangler Technical Forum 22 06-06-2012 09:14 AM
Transfer case shift linkage loose... dgi TJ Wrangler Technical Forum 2 10-07-2011 01:55 PM
Is this steering linkage too loose? (video) LandoCommando TJ Wrangler Technical Forum 15 08-22-2011 11:08 AM
shift linkage desmo TJ Wrangler Technical Forum 0 04-30-2007 01:36 PM
Transfer case linkage pops loose... again... Grubbi TJ Wrangler Technical Forum 5 10-30-2006 03:44 AM
