loose serpentine belt - JeepForum.com
post #1 of 9 Old 10-26-2005, 05:46 PM Thread Starter
funJ
funJ's Avatar
sorry... for a trivial question... i admit I am novice.
I changed my serpentine belt a few weeks ago. My jeep (tech info below) started to squeak like hell when it was cold. When it final warms up it goes away. I think that the belt is loose but I have been unable to pull the alternator any tighter than it is. Is there a trick to extend the alternator out more?
thanks
'88 Black Jeep Wrangler
4.2L 6cyl NV3550 Tranny
2.5 lift 31" x 11.5 tires
Special Features: Front Parking Lights light up when I hit the brakes...
Let me know if you are in a good club in Socal!
funJ is offline
post #2 of 9 Old 10-26-2005, 05:48 PM
badyjman
Use the adjustment bolt on the power steering pump mount.
RJC #315
1993 YJ, 2.5L, 2.5" Skyjacker military wrap lift, 8.8" rear, AX15 trans, and rust.
badyjman is offline
post #3 of 9 Old 10-26-2005, 05:49 PM
Jaymonkey
a pry bar and leverage, use the pry bar and pry against whatever you can get leverage against. Dont tighten to much....
______________________
89 YJ, 4.2L, 300KM and going strong
Pacesetter Header
Nutters Bypass
2.25" no-cat Exhaust
3" Lift
31" BFG AT's
Jaymonkey is offline
post #4 of 9 Old 10-26-2005, 06:06 PM
TellyDSP
Poland and PPV!!!!
I dont think its there on the 4.2. Think it's the alt.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #5 of 9 Old 10-26-2005, 06:56 PM
pyro9862
Why can't you pull the alternator further? If it's ajusted as far out as it will go you probably have the wrong belt. If you just can't pull it out anymore you just need more leverage.
pyro9862 is offline
post #6 of 9 Old 10-26-2005, 07:20 PM Thread Starter
funJ
funJ's Avatar
re
Thanks fort he help guys.
There is no lever on the fuel pump that is waht Chilton's said and I couldn't find it. The alternator is not extended all the way. I just pull it as much as possible by hand (even tried a hammer) and it doesn't get tight enough. It seems that the alternator is going so far or I am a weinee and can't pull hard enough. I'll try the crow bar and see what happens.... ]
funJ is offline
post #7 of 9 Old 10-26-2005, 08:36 PM
pyro9862
I've never seen anyone able to pull it tight by hand, you always have to use a bar just be careful not to overdue it and watch what you're prying off of.
pyro9862 is offline
post #8 of 9 Old 10-27-2005, 01:25 PM
bgmiller
I agree that you have to pry. Just replaced a belt on a 79 Bronco. Its not a serpentine, but I needed to remove the alternator belt. To replace it I pried against the tightened water pump. Not the same on the Jeep, but you get the idea.
1995 Wrangler
4.0L I6, 5 speed, 85k miles, 3.55, 3" suspension lift, 33x12.5 BFG's, lots of fun
bgmiller is offline
post #9 of 9 Old 11-10-2005, 07:15 PM
bakwoodj2
Use a Broom handle or a crow bar if you have one for a pry bar, just don't use the Power steering reservoir to pry against
2011 Natural Green Sport Unlimited
bakwoodj2 is offline
87 YJ serpentine belt 258 WITHOUT AC jeepguy85 YJ Wrangler Technical Forum 16 11-06-2012 04:09 PM
New belt tensioner but my belt is still loose 02tjsport TJ Wrangler Technical Forum 4 02-26-2009 12:33 PM
serpentine belt blevinsbulldog1 YJ Wrangler Technical Forum 13 02-26-2006 12:19 AM
Serpentine Belt Too Tight or loose??? heavyhitter YJ Wrangler Technical Forum 14 02-04-2006 07:47 PM
Serpentine belt R&R Vetteman YJ Wrangler Technical Forum 1 08-28-2003 08:16 PM
