looking to swap tranny's - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > looking to swap tranny's
Unread 06-22-2013, 08:45 PM   #1
shovelrunner
1987 YJ Wrangler
What would be the easiest bolt up trans to a 4.2 I'm looking to get rid of the Peugeot.it can anyone point me in the right direction as money is a little tight.
shovelrunner is offline   Reply With Quote Quick reply to this message
Unread 06-24-2013, 11:03 AM   #2
SamzJeep
Hey shovel...there's some good info in the FAQ section on this. I recently dropped in an AX15 and TC that was out of a '97 XJ. It wasn't too tough at all. I scored the tranny/tc/drive shaft (front XJ to be used for YJ rear after shortened/balanced/sye) and all shifter/linkage from Craigslist for 300 bucks. I used a pilot bearing for a '74 CJ5 V8, made my own tranny mount. If you change your clutch, make sure to use the pilot bearing tool to line up you clutch correctly. Check out the FAQ...there's a good write up on this exact swap. Then you can search for more write ups on this forum for further details if needed. I think I ended up paying about 350 for the entire tranny/tc swap. The XJ TC is slightly different than the YJ, so you have to clock the TC mounting holes 10 degree. Not too tough at all. Good luck....
SUPPORT OUR TROOPS
SamzJeep is offline   Reply With Quote Quick reply to this message
Unread 06-24-2013, 02:27 PM   #3
NHfireLJ
Jeeper Creeper
NHfireLJ's Avatar
NICE avatar!!!
now...
LUCY...2005 Unlimited "LJ" Rubicon Sahara #495 Build thread. http://www.jeepforum.com/forum/f9/my...hread-2778642/
BETTY...94 SE, Stroker 4.6, 4.5,lift,35"s,D30 Aussie, 8.8. Sold
NHfireLJ is offline   Reply With Quote Quick reply to this message
