Looking for suggestions... - JeepForum.com
post #1 of 5 Old 06-15-2013, 04:41 PM Thread Starter
geusey
1992 4.0 leaks oil. I'm pretty sure it's the rear main, but I am thinking of taking this opportunity to pick up a gasket set from Summit and replace all the seals. If I am going to have the engine opened up anyway, are there any other jobs you think I should do while I am at it? I am also considering an aftermarket cam as well. Something like the COMP cams 4x4. Any other ideas?
It seemed like a good idea at the time...
geusey is offline
post #2 of 5 Old 06-15-2013, 05:57 PM
bcusstc
While its not "in"the motor, i would do the oil filter adapter o rings as well..
bcusstc is offline
post #3 of 5 Old 06-15-2013, 11:46 PM
jokerchief462
When looking for an oil leak you have to remember a couple things. The oil flows two ways one by gravity and two by air flow in the engine bay so before you dismantle a lot of your Jeep check closely. You may want to clean it all up and find a fresh leak to be sure. A lot of oil leaks all end up dripping in that area mines was a bad valve cover gasket not the oil seal.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #4 of 5 Old 06-15-2013, 11:55 PM
rykemc
Oil pump and timing chain if you decide against the cam change.
My Jeep build. :)
APRIL 2013 YJOTM
JUNE 2014 YJOTM
rykemc is offline
post #5 of 5 Old 06-16-2013, 06:36 AM Thread Starter
geusey
Don't worry, i've already changed the valve cover gasket and cleaned it all up. I just got done with that little project not too long ago and stopped it leaking out the top, but there is still a leak coming from the back of the engine, and it got worse after I lifted the Jeep and the engine started sitting tilted back a little bit.
geusey is offline
