Looking at a modded 93 Sahara - JeepForum.com
post #1 of 5 Old 05-30-2007, 08:07 PM Thread Starter
BIGNUTT
BIGNUTT's Avatar
I am an XJ guy and new to YJs. I am just looking for a little advice/help.
Its a 93 YJ Sahara with 95k miles 4.0L/5-speed. It has 4.56s and detroits, new balljoints, an SYE, cv driveshaft, SOA lift, ARB bullbar, Warn 9k and rock rails for $5500.
I am wondering what to look for on this Jeep? I mean what are common issues for this model YJ?
Also I want to run 35s, I found a built 8.8 for the rear, but being SOA I noticed the steering is still stock. What do you guys usually do?
CANCER AND LUEKEMIA SUCK
Proud to be a Christian
BIGNUTT is offline
post #2 of 5 Old 05-30-2007, 08:35 PM
RoverJeep90
With all the work in that I'd say that probably isn't a bad deal--relatively low milage too. Although I'm no expert in the "highly modded rigs," my first inclination would be to take that at face value (all the upgrades) but look closer at the body wear, rust, etc. All the parts on the Jeep may be nice, but you need a decent tub, you know?
1990 Red YJ 2.54 L (Rebuilt) 5 Speed with 94 rollbar | Dynomax Exhaust | Luk Clutch
2.5" Old Man Emu over 31x10.50 BFG MTs on 15x8 AR 767s | 1" Daystar Body Lift
Two Tops | Full and Half Doors | KC Daylighters | Hella 5500 | OME Steering Stabiliser
Sony CDX-GT300 | Kicker ZX500.1 | Kicker ZX350.4 | Kicker ZX200.2 | Kicker L5 Solobaric Sub | Kicker 6x9's | Apline 6.5's | Boston 4x6's
Truckstop CB Antenna | Class 3 Hitch
RoverJeep90 is offline
post #3 of 5 Old 05-30-2007, 08:53 PM Thread Starter
BIGNUTT
BIGNUTT's Avatar
Ohh I know, I;ve owned many Jeeps, just never a YJ. I didn't know if there was anything YJ specific I might need to look into?
My plans (if you see anything wrong speak up):
TNT "phantom" fenders
PSC crusher corners, no flare with LEDs
PSC rocker knockers
MORE stubby bumper
TNT OTK steering system
99 Exploder 8.8 with 4.56s, ARB locker, alloy shafts
After that I am unsure, the bullbar will be sold and the rock rails and the locked/geared d35. I am still unsure about the suspension, but if it rides good I'll be okay for now, I like the height its at now, just will need bumpstop.
BIGNUTT is offline
post #4 of 5 Old 05-30-2007, 09:56 PM
SwearingYeti
SwearingYeti's Avatar
There are high steer kits floating around, Ive read about them, but have no real knowledge on the subject. Apparently they are $300+, but there are junkyard tricks to everything I suppose. Sounds like a good deal. Make sure the tranny doesnt grind, its about that mileage...
1991 Red YJ - 2.5L
1988 Red YJ -304ci
1989 OD XJ- 4.0L
SwearingYeti is offline
post #5 of 5 Old 05-30-2007, 10:24 PM
yjdrvr
if you can weld and are pretty experienced with it you can build your own high steer. my buddy did and it turned out great. he actually built his entire SOA himself. refuses to buy it. "Built not bought"
yjdrvr is offline
Weight of modded Tj Slick101 TJ Wrangler Technical Forum 21 02-06-2008 03:52 PM
I ALSO got a modded TJ recently! BigYellaJeep TJ Wrangler Technical Forum 36 06-13-2007 09:40 PM
Where are the modded 2 doors? yjing JK Wrangler Technical Forum 0 02-14-2007 11:15 PM
JK Already Getting Modded ... dspmans_04_X JK Wrangler Technical Forum 17 10-07-2006 10:00 AM
Modded '07? mpwal099 JK Wrangler Technical Forum 3 07-09-2006 10:36 AM
