looking for a LED front turn signal - Page 2 - JeepForum.com
post #16 of 54 Old 04-02-2013, 02:46 PM
flea1987
Originally Posted by UltimatE View Post
I run those. They are epically bright and look awesome. Only problem is, as you said, they require trimming ... and a bunch of fiddling with the electronics to get them to work. Then again any LED conversion will require fiddling with resistors and/or electronic based flashers
This should go in the cheap/cool mods thread, looks AMAZING, definately doing this to my yj
flea1987 is offline
post #17 of 54 Old 04-02-2013, 03:11 PM
SeanB95YJ
I did it over the summer... I was a little hesitant at first cutting into the grill, sort of a "no turning back now" moment... after having done it, there's no way I'd WANT to turn back
Sean B. - Schenectady, NY - 95 YJ, 350/700r4/NP241, JB Shorty SYE, 8.8 rear, 2" BDS, 1" homebrew shackles, Daystar 1" BL, TJ flares, 35x12.50 General Grabber AT2 on 15x10 Bart D-Truckers, Polyshield polycarbonate windshield, HD over/under crossover steering
swap/build thread:
SeanB95YJ is offline
post #18 of 54 Old 04-02-2013, 03:16 PM
flea1987
Attachment 599349
I see what you did there with the pun lol
flea1987 is offline
post #19 of 54 Old 04-05-2013, 11:44 AM
Robob69
Well I see what I am ordering Payday!!!! I love them!!
Robob69 is offline
post #20 of 54 Old 11-15-2013, 08:18 PM
aar
Will do this mod soon. Did the tail lights last weekend.
Does anybody have any suggestions on which lights to use for the front side reflectors?
aar is offline
post #21 of 54 Old 11-16-2013, 08:30 AM
Robob69
I used LED bulbs that work ok. I wish I could find some retrofit like the front light I put in.
Robob69 is offline
post #22 of 54 Old 11-16-2013, 08:33 AM
Robob69
These are my LED's. Love them.
Robob69 is offline
post #23 of 54 Old 11-16-2013, 09:16 AM
Richard_
Originally Posted by Robob69 View Post
Attachment 844889
where did you buy your headlights ?
Richard_ is offline
post #24 of 54 Old 11-16-2013, 09:28 AM
Robob69
They are aftermarket H4 upgrades I think I for them off eBay. Love them. I did the wire harness mod as well and lights are crazy bright.
Robob69 is offline
post #25 of 54 Old 11-16-2013, 09:34 AM
ReDinTX
They are aftermarket H4 upgrades I think I for them off eBay. Love them. I did the wire harness mod as well and lights are crazy bright. Sent from my iPhone using JeepForum
I did the same thing. I had 10 volts to the bulbs before the wiring harness mod. I got some 55/100 bulbs too. WORLD of difference!
-ReD
Fire Lieutenant/Paramedic
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #26 of 54 Old 11-16-2013, 09:50 AM
Robob69
Where did you get the bulbs?
Robob69 is offline
post #27 of 54 Old 11-16-2013, 12:49 PM
ReDinTX
Like this?
http://www.superbrightleds.com/cat/truck-box-lamps
http://www.4wheelparts.com/Lighting-...n=HLAH83140141
and the housings i have...
http://www.4wheelparts.com/Lighting-...&t_pn=POI27009
-ReD
San Antonio, Tx
'90 Yj 4.2L 5spd
ReDinTX is offline
post #28 of 54 Old 12-01-2013, 11:13 AM
aar
So... ended up getting a set of LED's like posted above.
I'm having issues with the wiring, have to admit I have not yet searched the forum for the solution. That cones next. I thought I ask here first.
Did the rear LED and replaced turn flasher with EL12. All works like stock.
With front ones, it works ok with running lights off, but does not flash for turn and indicator in dash (green arrow) is always illuminated.
Does the hazard flasher also need to be replaced?
How did you guys do the wiring?
LED's have 3 wires, like stock setting.
Thanks for the help.
aar is offline
post #29 of 54 Old 12-01-2013, 11:49 AM
Robob69
You must have a resistor for both right and left turn signals. I put mine behind the light and the air comes in the radiator opening and keeps them cool since they get real hot.
Robob69 is offline
post #30 of 54 Old 12-01-2013, 12:08 PM
aar
Thanks for the info, is it a Radio Shack item? If so part number or specs please
aar is offline
right front side maker/ front right turn signal light nonsense cvaria TJ Wrangler Technical Forum 6 02-09-2011 01:17 PM
front turn signal. Cesaros TJ Wrangler Technical Forum 13 02-07-2011 08:48 AM
front turn signal help Brian2o0o YJ Wrangler Technical Forum 5 12-21-2008 08:56 PM
front turn signal thetjkid TJ Wrangler Technical Forum 3 10-13-2004 12:07 PM
Front Turn Signal Question RCHavok797 YJ Wrangler Technical Forum 2 02-26-2004 05:38 AM
