looking for a LED front turn signal - JeepForum.com
post #1 of 54 Old 02-11-2011, 05:31 PM Thread Starter
green_jeep
does anyone know where i can find a front directional ( the one on the grill) thats an LED???
i found this one thats kinda close to the stock size just gotta trim the grill a little bit.if anyone knows of any direct fit LEDs not just the bulb but the whole lens could u post it? Thanks
http://www.superbrightleds.com/cgi-b...Frt.htm#photos
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
Jeep, Bike, and Street Rod, i NEED MORE money
green_jeep is offline
post #2 of 54 Old 02-11-2011, 06:54 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I run those. They are epically bright and look awesome. Only problem is, as you said, they require trimming ... and a bunch of fiddling with the electronics to get them to work. Then again any LED conversion will require fiddling with resistors and/or electronic based flashers
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #3 of 54 Old 02-11-2011, 08:33 PM Thread Starter
green_jeep
dude that looks great!!!!
i think im gonna order them lol
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
post #4 of 54 Old 02-11-2011, 09:23 PM
MJMPC
Why not just replace the bulb with a LED?
MIKE
MJM Powder Coating
Elizabethtown Ky.
MJMPC is offline
post #5 of 54 Old 02-11-2011, 09:57 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
LED bulbs would work, but you still have the stock crummy lens to shine through, unless you replace that as well (Even then the setup would be far from optimal). Also LED replacement bulbs for incandescents just aren't that great since LED's are directional, and incandescents are omni-directional.
With these replacements there are 24 forward facing LEDs with reflectors to maximize output. They're bright.
-Matt
White '94 YJ Sport
UltimatE is offline
post #6 of 54 Old 02-12-2011, 12:25 AM
SnowdogMarc
Those look sweet. I think I know what I'm doing when it warms up a bit.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #7 of 54 Old 02-12-2011, 05:22 AM
dodger889
If you look you do just the replacement bulb. They have several styles out now days ones that would be facing one direction or multi directional LEDs. That work just like an a indecent bulb. Also get the same color as the lens
http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&category=CAR&Page2Disp=% 2Fspecs%2F115x-x45-T.htm#photos
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #8 of 54 Old 02-12-2011, 08:33 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
$25 for a bulb? Hot damn. For $5 less you can get a much better performing setup and they look a lot better than stock.
-Matt
White '94 YJ Sport
UltimatE is offline
post #9 of 54 Old 02-12-2011, 11:43 AM Thread Starter
green_jeep
the reason i want led front lights is cause i am in the process of making a rear bumper with the LED sequential lights in it and gonna cut the tub for flush LED's
i just have to figure out what LEDs im gonna use for reverse lights
http://www.northerntool.com/shop/too...7595_200317595
http://www.northerntool.com/shop/too...9874_200009874
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
post #10 of 54 Old 02-12-2011, 01:46 PM
dodger889
Well unless you are going to run a separate wires for the turn signal light. You will not be able to use the amber light on the rear.
post #11 of 54 Old 02-12-2011, 05:50 PM Thread Starter
green_jeep
yeah i know im either gonna tap into my trailer harness for the sequential lights or wire them to a trailer plug and plug it into the tailer harness and when im gonna tow something just unplug it and plug in the tailer cause ur not gonna see them if i have a trailer hooked to the jeep anyway
l ______
/l ,[____],
l---L –OlllllllO-
()_) ()_)--o-)_)
post #12 of 54 Old 02-12-2011, 08:06 PM
dodger889
Your trailer connector will be the same you will still need to run a separate wires from the front to work and amber turn signal light on the rear. Because the rear brake light and signal lights are on a shared wired even to the trailer connector.
post #13 of 54 Old 04-02-2013, 09:27 AM
vwtipeii
vwtipeii's Avatar
any updates to this thread in a while? I am looking to do the same thing to my YJ and I wanted to see if any of you have done anything different the past 2-3 years.
Thanks
vwtipeii is offline
post #14 of 54 Old 04-02-2013, 02:14 PM
Dre40
I think I'm going to look into doing this my self I like how it looks.
92 YJ 4.3L Vortec SM-465/NP241.
80 CJ-7 4.5BT Cumminns Diesel still in building stage.
Dre40 is offline
post #15 of 54 Old 04-02-2013, 02:37 PM
Xpress
Thanks
Not really, the square LED's from SuperBrightLED's work well for turn signals. The red ones even work well for tail/turn/stop lamps too.
All about that unibody life.
Xpress is offline
right front side maker/ front right turn signal light nonsense cvaria TJ Wrangler Technical Forum 6 02-09-2011 01:17 PM
front turn signal. Cesaros TJ Wrangler Technical Forum 13 02-07-2011 08:48 AM
front turn signal help Brian2o0o YJ Wrangler Technical Forum 5 12-21-2008 08:56 PM
front turn signal thetjkid TJ Wrangler Technical Forum 3 10-13-2004 12:07 PM
Front Turn Signal Question RCHavok797 YJ Wrangler Technical Forum 2 02-26-2004 05:38 AM
