looking into swapping motors on budget - Page 2 - JeepForum.com
post #16 of 39 Old 02-26-2013, 08:35 PM Thread Starter
cwise737
For the 4.0 swap, what is everything I would need to complete the swap like parts wise
cwise737 is offline
post #17 of 39 Old 02-27-2013, 08:16 AM
Siva283
Motor/Trans/Transfer case.(You could also put a 23 spline input shaft into your current transfer case)Drive Shafts. Engine computer. SOme other misc. stuff.
Ask me how I know...
Siva283 is offline
post #18 of 39 Old 02-27-2013, 09:10 AM Thread Starter
cwise737
I would like to know if anyone has a list of all the parts needed
cwise737 is offline
post #19 of 39 Old 02-27-2013, 09:28 AM
Que89YJ
List:
Engine
Trans
Tcase
Driveshaft
ecu
2 injector wires to populate the old ecu connector or 4.0l engine wiring harness
motor mounts or reuse the 2 you have by cutting and moving
Que89YJ is offline
post #20 of 39 Old 02-27-2013, 12:10 PM
Siva283
You will always find you need misc bolts and things like that.
Sent from my Galaxy S3 using JeepForum
Siva283 is offline
post #21 of 39 Old 02-27-2013, 12:18 PM
imstillatwork
Originally Posted by Que89YJ View Post
List:
Engine
Trans
Tcase
Driveshaft
ecu
If you have a good machine shop nearby they can lengthen/shorten your shafts as needed for pretty cheap.
Remember this list is just the absolute basics. We can not make a complete list. It all depends on the condition of your items.
My 4.0 needs injectors, a clutch, a gasket kit, head bolts, etc...
Factor in another few hundred dollars on cleaners, oils, fluids, maintenance items, and other consumables during the procedure.
Whatever you THINK it will cost, double that and be happy when you are under budget. Or add up the basics and wonder why it cost SO much more in the end.
imstillatwork is offline
post #22 of 39 Old 02-27-2013, 06:16 PM
mncdriver
1987 YJ Wrangler
I just rebuilt my 6cyl, I had almost 600 bucks in just the bolt on parts, Gasket kit, timing chain cover, harmonic balancer, water pump, belts, rad hoses, heater hoses, spark plugs, distributer cap, rotor, plug wires, ign coil, pcv valve, clutch kit, ect. i did not want to put old used parts on a new engine build. Also look at a 4.3 v6, They are cheap to find, lighter than a 4.0/350 and make about 200 HP, of coarse you still need to do your homework and figure out what works best for you. Good Luck.
mncdriver is offline
post #23 of 39 Old 02-27-2013, 06:42 PM
BIGHEEP
Honestly, I think the cheapest way to do it is remove the lift, sell the Jeep and buy one with a 4.0L.
1981 Scrambler, Vortec 350,4L60e,D300, Currie 9" F&R
19xx YJ/CJ/TJ/XJ/Waggy thing 4.0L H.O., AW4,
NP231 w/HD SYE,D44 locked/D44 w/LSD,4.09 gears
Build thread
North East Willy Jeep Organization
BIGHEEP is offline
post #24 of 39 Old 02-27-2013, 06:52 PM
jeepcrazy93
Ive done the 2.5 to 4.0 swap. Not that difficult but i was doing a bunch of other things while i had it apart. Make sure you have the ax-15 mount plate and Tcase shifter. They can be tricky items to find in the middle of a swap.
93 YJ 4.0 AX-15 33's 8.8 with CJ front clip
03 F-250 Extended Cab Long Bed with 7.3
jeepcrazy93 is offline
post #25 of 39 Old 02-28-2013, 09:48 AM Thread Starter
cwise737
One does not simply sell the jeep they've been building since they were 14 lol
cwise737 is offline
post #26 of 39 Old 02-28-2013, 09:49 AM Thread Starter
cwise737
I appreciate the help guys its making this whole process of what I need to be looking for so much easier
cwise737 is offline
post #27 of 39 Old 02-28-2013, 03:06 PM
Hghgrad
I like your thinking
It's not always cheaper to sell it and buy a 4.0 version. There's no way I could have picked up a 4.0 yj for anywhere near what I have invested in mine. I think I'm still under $2500 invested in mine, including the initial $1000 jeep.
1994 Wrangler...4.0 AW4 swapped, sye'd, 5.5" lift and 33's
Hghgrad is offline
post #28 of 39 Old 02-28-2013, 07:15 PM
imstillatwork
Edit:
My Reading and Comprehension: Needs Improvement.
post #29 of 39 Old 03-03-2013, 02:35 PM Thread Starter
cwise737
After further review and what I would like I might possibly be selling my jeep but to get a tj because of the reliability and better ride but will not be for a while to get me some money
cwise737 is offline
post #30 of 39 Old 05-22-2013, 09:45 AM Thread Starter
cwise737
To keep everyone updated I just bought myself a 350 and I'm doing the full axle and everything. Taking the tub off today and doing a full frame off
cwise737 is offline
