Looking for input on spare tire - JeepForum.com
post #1 of 12 Old 11-01-2011, 05:26 PM Thread Starter
sconnors
I currently have no spare tire and am running 31x10.50x15 tires and wheels on my 1995 Wrangler. Thinking of putting a spare on there and am wondering if a tire/wheel combination this big is going to cause a problem with the stock spare tire holder on my Jeep?
Any input would be greatly appreciated
Scott
sconnors is offline
post #2 of 12 Old 11-01-2011, 05:43 PM
copleydad
copleydad's Avatar
That's the maximum size I'd put back there. I've had a 30x9.5x15 for a few years with no issues, and have some wiggle room for the 31's when I go to replace the tires, probably this time next year. I wouldn't go any bigger than 31's, personally.
'89 Islander 4.2l 5 speed
'14 Grand Cherokee Limited 3.6
One Jeep is Never Enough
copleydad is offline
post #3 of 12 Old 11-01-2011, 06:15 PM
jbolty
jbolty's Avatar
I had a 33 on the stock carrier for about a year with no problem. The main issue is to make sure it's solidly bolted so there is no flopping and moving leading to breakage.
"The right to be heard does not necessarily include the right to be taken seriously." óHubert Humphrey
jbolty is offline
post #4 of 12 Old 11-03-2011, 12:10 AM
SnowdogMarc
I have a 33 on mine and just needed to add some hockey pucks behind the stock bumpers to get the proper spacing. Have run this for 2 years with no problems and a buddy of mine has a 37 on his TJ for over 4 and no problems
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #5 of 12 Old 11-03-2011, 12:49 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
It's not going to work with your setup. Summertime: yes. The stock carrier with 31 10.50 tires will hinder your hardtop liftgate in the opening and closing process. I played that game for a bit and it just didn't fly. I had to build a swing out carrier for mine.
Luck Favours The Prepared
Anticanman is offline
post #6 of 12 Old 11-03-2011, 01:18 AM
SnowdogMarc
Remove or shorten the bump stop for the gate and it will work no problem
l_______
/l ,[_____],
l---L -[]lllllll[]-
post #7 of 12 Old 11-03-2011, 02:22 AM
tankinyj
my full size spare (31x10.50x15) rubs my bumper, but i have an aftermarket bumper. you cannot go bigger than a 31" spare on the back without a aftermarket tire carrier
2012 JK, 44s, rubi case, 37" PBRs, stretched 8"
Crush Orange Jeep Member #55
NYC Jeep Club
tankinyj is offline
post #8 of 12 Old 11-03-2011, 06:10 AM
Louie4
I used to run a 33" spare on my stock setup. I don't anymore.
My buddy pondering the situation.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 12 Old 11-03-2011, 06:37 AM
nsahan
I have a 33 on there for 4 years now. with no problem
nsahan is offline
post #10 of 12 Old 11-03-2011, 06:55 AM
1998zj
I have been running a 35 back there for a couple of years. A 33 for a couple before that. Make sure it isn't bouncing around and you should be fine.
"Our lady of blessed acceleration don't fail me now"
1998zj is offline
post #11 of 12 Old 11-03-2011, 01:03 PM
jmmorgan82
2009 JK Wrangler
See the following thread: Click Here. Throw on that tailgate reinforcement kit and some TJ hinges and you wouldn't have a thing to worry about.
jmmorgan82 is offline
post #12 of 12 Old 11-03-2011, 02:40 PM
Louie4
I have that kit and I believe that's one reason the tub didn't bend. The tailgate also stayed fairly straight. My stock hinges bent pretty good though.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
PISSED! OEM Spare Tire Carrier Bolts Just Spinning, Can't Get Spare Off! IDEAS!?! chicagoanalog TJ Wrangler Technical Forum 20 09-24-2012 06:12 PM
Spare tire spacer Jeep Wrangler TJ extender hold 35in tire gollas8 TJ Wrangler Technical Forum 3 03-31-2011 06:01 AM
spare me your time (spare tire carrier/spare tire) TJBugsmasher TJ Wrangler Technical Forum 22 11-16-2009 03:35 PM
33'' spare on stock spare tire mount: Suggestions Yellowhammer TJ Wrangler Technical Forum 49 10-31-2009 11:06 AM
Spare Tire Bike Rack for my TJ with 31" spare my911cab TJ Wrangler Technical Forum 6 06-25-2005 03:30 PM
