looking for help with transfer case vaccum switch - JeepForum.com
post #1 of 9 Old 10-23-2011, 06:34 AM Thread Starter
ptrcrynn
Is there an easy way to change this vaccum switch? Is there a write up that I could refer to I was looking and didn't come across one so thought maybe someone did this. Or can I access the switch through the shifter area.
Thank you in advance for any help you can give.
Pat
ptrcrynn is offline
post #2 of 9 Old 10-23-2011, 06:39 AM
Louie4
IIRC, I was able to get up in there with some channel locks and break it loose, then take it off by hand. When you reinstall, put some teflon tape on the threads to keep it from leaking.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 9 Old 10-23-2011, 06:43 AM
jay-h
I had to buy a socket, it was too tight for channelloks like the previous poster. Unfortunately it was an odd size (1-3/16?) and I don't remember the exact size at the moment.
jay-h is offline
post #4 of 9 Old 10-23-2011, 06:46 AM Thread Starter
ptrcrynn
Thank you for your response I definantly try both.
ptrcrynn is offline
post #5 of 9 Old 10-23-2011, 01:04 PM
moonshinefuel
I did document my experience which should be of some help here. http://www.jeepforum.com/forum/f12/4...fixed-1121523/
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #6 of 9 Old 10-23-2011, 01:54 PM
lancer27
If you have trouble getting to it drop your skid Down an inch or to give a little more room to work with.
97 tj i6 3.5 RE superflex lift. hp dana 30 4.56 gears ausie up front. dana 44 33spline alloy usa shafts arb rear. tom woods supper short sye and matching cv ds. 35x12.50x15 goodyear MTR's with kevlar. york OBA system. Metal Cloak High Arch tube fenders!(my favorit mod!!!)
lancer27 is offline
post #7 of 9 Old 10-23-2011, 04:14 PM Thread Starter
ptrcrynn
Thank you for all the help we have changed the switch and all is well eazy peazy japaneazy 15 mins
Pat
ptrcrynn is offline
post #8 of 9 Old 10-24-2011, 11:09 AM
Brown Dog
Vendor
Brown Dog's Avatar
30 MM socket, I believe.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #9 of 9 Old 10-24-2011, 05:52 PM Thread Starter
ptrcrynn
1 1/16th deepdish worked perfect
ptrcrynn is offline
Writeup on bypassing transfer case switch for CAD with manual vacuum switch dancytron YJ Wrangler Technical Forum 3 08-02-2011 07:34 PM
Transfer Case Switch mschramek TJ Wrangler Technical Forum 7 12-17-2010 07:06 PM
transfer case vac switch xxgunrunnerxx YJ Wrangler Technical Forum 7 12-08-2009 01:59 PM
transfer case switch? dwaynetm1 YJ Wrangler Technical Forum 3 05-19-2009 06:16 PM
Transfer case vaccuum case switch Hambne YJ Wrangler Technical Forum 7 07-11-2007 04:36 PM
