Looking for HD Dana 30 axle shaft upgrade - need part number - JeepForum.com
post #1 of 6 Old 02-04-2006, 12:52 AM Thread Starter
Mark_ZZ3
Mark_ZZ3's Avatar
Looks like I have to replace the passenger side axle shaft since it is leaking for the second time! Thought I could get away with a new seal, but there must be pitting or a grove on the shaft.
So what to do?
- Buy a stock replacement for a 1991 YJ?
- Buy a stock replacement for a 1995 YJ (with 297 ujoints)
- Put in aftermarket HD unit?
I have looked for replacement for the Vac-Disconnect passenger side, but everyone sells the full shaft from the XJ. Warn has some, but they require the hub conversion.
Does anyone make HD replacements that retain the Vac Disc. and the stock hubs?
Mark.
Mark_ZZ3 is offline
post #2 of 6 Old 02-04-2006, 08:15 AM
kcdee00
randy's ring and pinion
When I broke the ears on the passenger side shaft, I went with the vaccuum eliminator parts from randy's ring and pinion....it comes with everything you need and I got a chromoly shaft with it....I dont have their # right now, but I'm sure you can find it on the net....give them a call, real nice to deal with, and see if they can help
95YJ, d44 front, 8.8 rear (aussie locker), 5.13's, SOA, 36" Iroks
kcdee00 is offline
post #3 of 6 Old 02-04-2006, 10:21 AM
Tomb Raider
Addicted...
Tomb Raider's Avatar
So what to do?
Mark.
Try http://superioraxle.com/htmlfolder/frontaxle.html
They don't sell retail...but that would give you a part number you can give one of their distributors.
Tomb Raider is offline
post #4 of 6 Old 02-04-2006, 11:08 AM Thread Starter
Mark_ZZ3
Mark_ZZ3's Avatar
I've checked superior axle and a couple others, and the only listing they have is for the long shaft that replaced the vac-disc. I was hoping to find a stock replacment with the disconnect.
I'd prefer to keep the vac-disc as I drive it every day (save on gas and vibrations). And I don't really want to spend the money (just yet) on a hub conversion.
So it looks like a 1995 YJ part is my best choice.
Mark.
Mark_ZZ3 is offline
post #5 of 6 Old 02-04-2006, 01:52 PM
heavyhitter
heavyhitter's Avatar
Mark.
The two peice axle does not save a whole lot in gas if any. I would eliminate that disconect in a heartbeat. And never look back.
Awesome flyfishing pics and vids here
93 YJ almighty 4banger, 31" bfg all terrains on 15x8 ar black steelies, 1.25" PA shackle lift, pioneer stereo system, herculined tub, TJ Flares, Rock Sliders, custom front & rear bumpers,
heavyhitter is offline
post #6 of 6 Old 02-05-2006, 12:57 AM Thread Starter
Mark_ZZ3
Mark_ZZ3's Avatar
I agree that eliminating the vac disc is a good thing, however my front driveshaft angle is not great for high speeds.
When I installed my lift, I lifted the engine, lowered the transfer case (slightly) to accomodate the rear driveline angle. It runs smooth now. However in 4 hi, anything about 35MPH you get a vibration.
So eliminating the Vac Disc would also mean fixing the front driveline angle ... most likely a SYE and put the transfer case back to where it was.
Mark.
Mark_ZZ3 is offline
7 Blade Fan Upgrade Part Number SmackLayer TJ Wrangler Technical Forum 30 04-07-2012 10:42 PM
rubicon dana 44 front axle part number!!! mustgooverit TJ Wrangler Technical Forum 14 09-10-2011 01:24 PM
Dana 44 axle shaft bearing part #'s? thejafe TJ Wrangler Technical Forum 8 02-28-2011 11:52 AM
cheap upgrade for DANA 30 axle shaft barry1me TJ Wrangler Technical Forum 3 07-18-2006 09:34 AM
Yukon D30 Axle Shaft U-Joint? part number blackjeep04 TJ Wrangler Technical Forum 5 07-26-2005 05:48 AM
