Looking for advice - How to secure top to windshield - JeepForum.com
post #1 of 32 Old 03-12-2014, 10:57 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Hi everyone
I am looking for ideas on how to properly secure the top to the windshield frame, the screws on mine have stripped, and the lip that holds the screws on the top is damaged because of the vibration, see attached picture.
I thought about making new holes for new screws, but maybe someone came up with an idea to fix this problem for good. I don't like the rattling and vibration and would like to find a solution.
Here the pic, thanks!
Originally Posted by JeepHammer
I don't mind writing for Fernando because he reads, and re-reads EVERY WORD!... Good to write for someone that actually READS the answer, and takes time to UNDERSTAND what comes back for an answer!
Fernando is online now
post #2 of 32 Old 03-12-2014, 11:18 AM
Mobile_Homie
Desert Rat
Mobile_Homie's Avatar
Just move the screws over an inch or so...
Mark
Smoke em if you got em!
Mobile_Homie is offline
post #3 of 32 Old 03-12-2014, 11:19 AM
Xpress
x2. Use good screws...
All about that unibody life.
Xpress is offline
post #4 of 32 Old 03-12-2014, 11:39 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Thank you... should I use pressure washers?
post #5 of 32 Old 03-12-2014, 11:47 AM
Mobile_Homie
Desert Rat
I would use a flat washer along with lock washers. Get yourself some self tapping sheetmetal screws and pre-drill the holes a little small.
Mark
post #6 of 32 Old 03-12-2014, 11:50 AM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
Perfect, thank you!
post #7 of 32 Old 03-12-2014, 11:52 AM
fratis
fratis's Avatar
id do nutcerts...
-insert meaningless out-of-place political diatribe-
fratis is offline
post #8 of 32 Old 03-12-2014, 11:59 AM
YJ4LIFE
Originally Posted by fratis View Post
id do nutcerts...
I did that last time
'89 YJ, 4.2L, ax-15, B&M shifter, 1" BL, TJ flares, '99 intake, '91 EFI, 5.0L explorer injectors, GenRight tank & stretch, 35" ProComp Xtreme muds, 52" chevy springs rear, 44044 Ranchos front.....
YJ4LIFE is offline
post #9 of 32 Old 03-12-2014, 12:02 PM
CrawlingForward
I just switched to a larger screw....
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #10 of 32 Old 03-12-2014, 12:54 PM
Firefyter-Emt
Look for "flush mount" nut- inserts, they are the best fix. I would also but the zinc plates ones over the aluminum inserts. Combine that with stainless steel bolts and flat washers.
But enough to use for the soft top / bikini top if you have one. I ran this for years on my old Jeep, and have done the soft top holed on the new one. Amazingly enough, the STOCK screws all still hold for the hard top!!
Firefyter-Emt is offline
post #11 of 32 Old 03-12-2014, 01:24 PM
rodgers3
Why does the top need to be screwed down? I didnt screw it down when I put the top back on before winter. The bar rattles a little sometimes but it sealed tight and doest leak..
rodgers3 is offline
post #12 of 32 Old 03-12-2014, 01:28 PM
cwstnsko
If you end up going with new holes and screws, for the strongest, longest lasting installation, drill tiny holes for the screws and use a small tapered punch to enlarge the hole without removing material. The effect you are going for is what is shown in this picture:
You will never really get the shape shown without being able to support it from the back side, but the intent is to leave as much material as possible surrounding the hole, so the screw has a lot more to bite in to and won't strip out as easily.
You can probably get a lot of the same benefits by just starting with a very small hole and using self piercing screws that look like this
cwstnsko is offline
post #13 of 32 Old 03-12-2014, 06:40 PM
JWELK
Fill the old holes, there is more than one post here describing how to repair rusted window frames. All resulting from missing screws.
JWELK is offline
post #14 of 32 Old 03-14-2014, 02:10 PM Thread Starter
Fernando
Fernando's Avatar
1987 YJ Wrangler
id do nutcerts...
Thank you very much indeed!! this is the kind of solution I was sort of hoping someone would mention, something stronger and more reliable. By any chance, do you know where I can buy them?
Thank you very much!
I did this last time, roads in Costa Rica are terrible, eventually all the screws stripped, I will try the nutserts
Any suggestions on how to repair the holes?
post #15 of 32 Old 03-15-2014, 01:16 PM
XJ93
Your local auto parts store should be able to help you with nutcerts. I can give you the NAPA part numbers for the kit. 770-2875 is the kit number. You can also get the tool by itself and boxes of nutcerts. I have one of these kits and it has proved its worth several times.
XJ93 is offline
