Looking at a 94 4.0L things to look for and lift questions? - JeepForum.com
post #1 of 3 Old 05-05-2008, 09:49 PM Thread Starter
broncofire75
Hey guys first post in the YJ forum!
Anyways I'm a XJ guy and found a goo ddeal on a DD 94 YJ. 4.o auto soft top that stuff. Its stock and I want to make 3/4" shackles and get a 1" BL. Also, considering a 2.5" leaf kit. What are good kits and things to watch for when buying them?
I've been skimming then x.x" lift with xx" tires thread for a while and it seems like the 4.5" kits fit 33s fine and I want to run 32s and stock gears. I'm going to make a front winch bumper and maybe a rear. Sliders definately also.
Can I get away with 4" and jus a 1" transfer case drop?
Thanks for the input definately new to YJs not to Jeeps though thats why I'm sticking with them.
-1998 XJ Sport 4.0L-
-6.5" RE/Rustys/RC lift, Custom Y-link LAs, custom shackle relocation boxes, Pro Comp/RE monos-
-315/75/16 Toyo MTs on Moabs-
-Shaved 8.25 w/HD shafts/Auburn LS/4:10s, HP30 w/ Lock-right, sliders, HD track bar bracket, AA SYE, AppA TC skid, AFE intake, Magnaflow exhaust, Bored TB-
broncofire75 is offline
post #2 of 3 Old 05-07-2008, 08:09 AM Thread Starter
broncofire75
Anyone got some info?
post #3 of 3 Old 05-07-2008, 08:35 AM
vmkwrangler
Most common lifts recommended are BDS, Rubicon Express, and Old Man Emu. Most will agree all give fair ride. Most will tell you to stay away for Pro Comp, Rough County for sure. In other words cheap= poor ride and flex. I don't know about how much drop is needed for 4" lifts. I and lot of others have cut out wheel wells and put on tj flares, this will open of the wheels wells quite of bit, but you much cut your jeep to really help. I know the search can give you trouble to find what you are looking for, you might look at a couple pages of old threads and see what people are stay about their junk, good and bad. Hope this helps
1994 YJ 4.0, Refreshed AX15
4.10's w/ 8.8 Rear end
OME HD suspension
Ramsey Rep 9.5e
TJ Flares, 32x11.50's
vmkwrangler is offline
YJ lift kits for first timers...some things to think about... squibload YJ Wrangler Technical Forum 29 04-26-2010 09:23 AM
What other things does a lift kit effect? Wranglerkid77 TJ Wrangler Technical Forum 10 01-26-2009 08:54 AM
Lift? OR Fix some semi minor things? jaminb YJ Wrangler Technical Forum 17 03-08-2008 12:56 PM
Planning the lift on my next jeep, just wondering a few things. TheyStoleMyShoe TJ Wrangler Technical Forum 8 11-04-2004 06:04 PM
I want to Lift my Jeep, and other things.... JackRabbit YJ Wrangler Technical Forum 7 01-26-2004 10:07 AM
