looking at a 89 or 91 grand wagoneer for donor vehicle - JeepForum.com
post #1 of 5 Old 07-12-2010, 09:22 AM Thread Starter
mark12010
mark12010's Avatar
I have a line on 2 grand wagoneers one a 91 and the other a 89. my question is can I swap the entire drivetrain into my 90YJ (engine,tranny and TC) besides motor mounts what else should i need. Also what is involved in swapping out the rear axle (D44) any major issues there? I have a great running 4.0 in there now but I think I am getting the urge for a V8.
mark12010 is offline
post #2 of 5 Old 07-12-2010, 07:58 PM Thread Starter
mark12010
mark12010's Avatar
No one has any input here???
post #3 of 5 Old 07-12-2010, 08:11 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Personally, I'd avoid it like the plague.
The Dana 44 swap is okay I guess, but then you have the 6 lug issue to deal with (6 lug rear, 5 lug front) or swap both axles and spend a LOT of time swapping out a Dana 30 that is a great axle to begin with.
The AMC 360 shares nothing with the Dodge 360, so parts are limited & it's never been a "powerhouse" V8 even on it's best day.
IMO, if you want a V8, find a 5.7L Chevy with 700r4/NP231 combo and get a Ford 8.8 rear axle. You'll get a lot more bang for your buck.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #4 of 5 Old 07-12-2010, 09:23 PM
MLJeeper
MLJeeper's Avatar
That 360 in the waggy is a serious gas PIG. The two i had averaged 9 mpg. 3 speed with no OD.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #5 of 5 Old 07-12-2010, 10:24 PM
MoparFreak69
From what I have heard from local shops around here you can take a D44 down to 5x4.5 so you can keep your wheels and tires you currently have. Take that with a grain of salt though as I have yet to even start the search and serious research part of that swap. I am going to do D44's on both ends and call it a day despite all the bashing they receive. I will never run a 4 letter F word in any of my rigs so my only axle options are Chrysler corporate (8 3/4 isnt a bad axle at all) or Danas. 44's see a nice balance between power handling and size for what I want to do. Besides I like to think that while wheeling I am generally pretty easy on my rigs so I bet my D35 would even last under my 5.2 for quite some time.
As far as the AMC 360, its a great motor. Sure there isnt a ton of aftermarket support for it anymore, but you can still do a lot of things to them and make good power, mostly down low where you want it to be anyway. If you play your cards right you can get an AMC that has a 727 behind it. What that means is you can throw a later trans (OD 42RH anybody?) behind it and give it a chance of making some better fuel mileage for you. Basically it all amounts to how much research do you want to do and how much effort are you willing to put into the swap.
And for those suggesting a GM drivetrain swap, take a minute and think, why are they so plentiful in the junkyards? Leave em where they lay (and belong) and go with a brand known for something other than 100K mile throw away toy cars.
90 YJ 5.2 Magnum, AX-15, 231 SYE'd
D44 front, welded/trussed AMC20HD rear. 4.56 gears soonish.
Western 6 lug aluminum wheels, with 35x12.50x15 Wrangler MTRs
MoparFreak69 is offline
donor vehicle 95jy YJ Wrangler Technical Forum 1 12-09-2009 12:31 PM
Donor vehicle? ceasar_1 TJ Wrangler Technical Forum 6 08-09-2009 06:17 AM
What axle from what donor vehicle? Grim Jeeper TJ Wrangler Technical Forum 21 04-25-2007 09:08 AM
I got a donor vehicle today dennis690 YJ Wrangler Technical Forum 1 04-05-2006 05:37 PM
It's official, Got a donor vehicle!! Tomb Raider YJ Wrangler Technical Forum 31 03-17-2006 02:39 PM
