Looking a 8.8 to Purchase, Questions??? - Page 2 - JeepForum.com
post #16 of 41 Old 12-27-2011, 12:24 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Cost breakdown looks a little like this per axle:
$200 gears
$100 Set up kit (bearings and seals)
$50-1000 carrier (from Craigslist to ARB)
$300-500 labor
3.73 isn't bad with 33's. I'm running 4.10 with 36's and on the freeway it's perfect. Offroad it's a little sluggish but that's why I have 4:1 TC gears. You'll more than enjoy the power gains from the gear change and possibly be able to stay 2wd if you're doing one axle at a time.
Good luck!
Luck Favours The Prepared
Anticanman is offline
post #17 of 41 Old 12-27-2011, 02:09 AM Thread Starter
HanksRide
$200 gears
$300-500 labor
Good luck!
Thanks Anticanman, I think that is what I am going to do.. I figured I would have a $1K wrapped up in this before I was done.. I think that will get me where I want to be and I can live with 3.73's.. I actually haven't minded my 3.07's that much other than when I occasionally wish for a burst of speed that is not there, but driving around town 1st, 2nd, and 3rd is not to bad.. And yes that is my plan, keep it 2wd and work one at a time.
HanksRide
(Hank is Yellow Lab) He loves it!!
95yj 4.0L, 4" RC Lift, 8.8, Aussie Locker, Posi-Lok, Rock Sliders, 1" Booms, 33 X 12.50's, Rhino Lining, KC Day Lighters, Rock Bumpers, LED Dash Lights, XRC10 Winch
HanksRide is offline
post #18 of 41 Old 12-27-2011, 02:39 AM Thread Starter
HanksRide
Is this the type gears I am looking for "Reverse Gear Set" for the Dana 30?
Dana 30 3.73 Reverse Gear Set By Alloy USA - D30373R
Or is it the Standard Gear Set??
HanksRide
post #19 of 41 Old 12-27-2011, 05:51 AM
wickedoffroad
1987 YJ Wrangler
Not sure about the gears or the locker....but the perches are a snap to get on. Any 4x4 store worth their salt will offer a range of weld on perches for a reasonable cost. If your friend can weld and you can operate an angle finder there is no reason to pay someone else to put your perches on. You can also relocate the rear shock mounts so they arent hanging below the axle. You will be able to use your stock e-brake cable with the included 8.8 e-brake hardware with little modification.
wickedoffroad is offline
post #20 of 41 Old 12-27-2011, 07:37 AM
dodger889
You will need reverse cut for your D30. Also you will need to add a carrier for those gears. The cut off is the carrier is between ?.??-3.54 and 3.73-?.?? gear sets. This will be good if you want to ever go into the lower gears latter.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #21 of 41 Old 12-27-2011, 08:00 AM
dillonjm
2013 WK
+1
And a general comment to the OP. I think you are taking a perfectly reasonable route to getting a good reliable setup under your rig. I too decided to regear my axles (albiet I was forced to because no one had stock 4.88's, but if I couldn't have found a 4.10 8.8 I'd just get one and regear it too). It sounds like you're going to have someone setup your axles for you, might be worth your time to see if they'd let you help/observe. Its a good learning experience, I taught myself gears when I went to 4.88's and am really glad I did. The differential isn't some mystery box anymore.
Good luck with your build, sounds like you're going to have one really capable and reliable rig when your done.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #22 of 41 Old 12-27-2011, 10:47 AM
timatoe
timatoe's Avatar
Originally Posted by HanksRide View Post
OK give me the con's to staying with 3.73's front and back.. Then I only have to regear the front.. I have been running 3.07's for a couple of years on 33's, it has got to be a huge improvement over that.. I also use it as my DD most of the time and at times take some road trips (several miles) in it, I assume staying with 3.73's would be a little better on MPG than 4.10's would. I did the RPM calculator and 3.73's will put my at 2250 @60 MPH as apposed to 1825 with 3.07's and 2500'ish with 4.10's. All this is with 33's...
In this case I'd stay at the 3.73's. I had factory 3.73's and kept them up until I went to 35's and it was just too high revving in the rocks at that point. For mostly road use and light offroading you'll be pretty good with 3.73's.
timatoe is offline
post #23 of 41 Old 12-27-2011, 12:02 PM Thread Starter
HanksRide
Thanks timatoe, I think that is what I am going to do.. I am going to visit a local fab shop this afternoon about welding perch mounts etc for me.. I am also going to do some checking around about regearing the D-30 and see what I come up with..
HanksRide
post #24 of 41 Old 12-27-2011, 12:23 PM Thread Starter
HanksRide
Well getting ready to pull the trigger on some gears and bearings for the D-30.. What brand of gears are good? I assume they are not all created equal.. I hope this is not one of those confrontational questions where there are a million opinions like (track bars or no track bars)
I have found several different types or brands of gears out there with only a few penny's difference in price but I want to make sure I put quality gears in.
I talked to a shop that will do the re-gear & bearings for $350.00 if I supply the parts. . I think this is the route I am going to go, I have read to many threads of people blowing rear-ends from them trying to do it them selves. This is costing enough as is without me having to pay for it all again in the long run.. Besides they offer a warranty on the work and that is worth something to me.
Does anyone offer a complete rebuild kit, gears, bearings etc for this as a package that is quality parts?
HanksRide
post #25 of 41 Old 12-27-2011, 01:12 PM
dodger889
Richmonds gears are a know brand Splicer( DANA) is another. Those are off the top of my head.
post #26 of 41 Old 12-27-2011, 01:25 PM Thread Starter
HanksRide
How are Precision Gears, anyone have an opinion?? There is something strange about this 3.73 ratio, they are like 2X higher than any other ratio. I am assuming it is because of lack of demand...
Jeep4X4center.com has the Precision Gears for $174.00, that is like 100 bucks cheaper than most I have found..
HanksRide
post #27 of 41 Old 01-01-2012, 07:39 PM
yj87ben
Hank, Before you go shopping at the 4X4.com web sites, check craigslist and eBay. You can usually get better prices and sometimes free shipping.
yj87ben is offline
post #28 of 41 Old 01-01-2012, 07:43 PM
dillonjm
2013 WK
That seems pretty cheap from the quick search I just ran. I don't have any experience with Precision gears, however.
For what its worth, I've been pretty happy with the Yukon gearsets and spartan locker (a Yukon product too) I put in my Jeep. I think Randy's sells them for about $225 in the 3.73 variety.
dillonjm is offline
post #29 of 41 Old 01-01-2012, 07:56 PM Thread Starter
HanksRide
Well I guess the price doesn't really matter now.. I am going to let a local shop set my D-30 up with gears and the deal is if I buy them they will not warranty the work but if they buy them I have to pay their prices for the gears. They guy told me that 3.73 gears were the most expensive due to lack of demand. I think about $250.00 is what they are going to charge me for the gears.
Ok here is the deal on my 3.73 and the decision that I have gone with.. Right now with 3.07's it is a dog at best but I do get pretty good gas mileage and sorry to admit but most of my driving in the heep is to work or on the highway with the occasional wheeling trip now and then therefore gas mileage is a little more important to me then if I was just building a wheelin jeep only would be. And according to this chart 3.73 is exactly where I want to be.
http://www.offroaders.com/tech/gear-ratio-chart.htm
If I want to drive 65 - 70 on the interstate I don't want it winding the engine to the point that it is a little annoying to me or running out of top in at that speed. I know that this conversion is going to cost me more in the long run then going with 4.10's and a d-30 from a 4 cylinder but I plan on driving this thing for a lot of years to come so I think it will be worth it to me to get the gear set that best suits my driving habits..
HanksRide
post #30 of 41 Old 01-01-2012, 07:58 PM Thread Starter
HanksRide
Thanks yj87ben, I will keep that in mind in the future.. I do visit the vendor section of jeep forum and spend a lot of time on CL and eBay.. I think I just have bad luck sometimes finding what I am looking for especially CL..
HanksRide
purchase questions Deuskid TJ Wrangler Technical Forum 7 06-01-2011 07:53 PM
Questions regarding purchase of 1st TJ 1398653 TJ Wrangler Technical Forum 8 07-07-2009 12:12 PM
Going to purchase a YJ, but a few questions... svt_4_me YJ Wrangler Technical Forum 13 06-29-2007 07:42 AM
Pre-purchase questions. Existence JK Wrangler Technical Forum 3 05-08-2007 08:45 PM
New purchase and some questions Jeep225 YJ Wrangler Technical Forum 2 10-03-2004 04:45 PM
