lookin into the yj - Page 2 - JeepForum.com
post #16 of 22 Old 08-19-2011, 06:30 PM
dimatrod
It looks nice! Is it a 4cyl or 6cyl? Also save up $200-300 for a SYE+longer driveshaft, since 4" lift will put stress on that slip yoke as well as maybe just slipping out lol.
dimatrod is offline
post #17 of 22 Old 08-19-2011, 06:38 PM Thread Starter
slamin04
2011 JK Wrangler
its is a six
PAY IT FOWARD Garage Buildin!!!
http://www.flickr.com/photos/cosmos111/
slamin04 is offline
post #18 of 22 Old 08-19-2011, 06:40 PM Thread Starter
slamin04
2011 JK Wrangler
that would suck
slamin04 is offline
post #19 of 22 Old 08-19-2011, 06:56 PM
Skydmark1
Originally Posted by slamin04 View Post
that would suck
I would drive it and see if it has any driveline vibrations. Like I say, I have that same lift no SYE with a T-case drop and it's fine. It really depends, 4" of lift is right on the border, seems like some Jeeps need an SYE and some don't. I would say you will definetly need a T-case drop or motor mount lift though.
-2013 JKU Sport, bone stock, Auto with 3.73's
-1998 ZJ Laredo, 4.0 42RE Selec-Track, 30" M/T tires
Skydmark1 is offline
post #20 of 22 Old 08-20-2011, 01:51 PM Thread Starter
slamin04
2011 JK Wrangler
well guys went and drove the yj today runs out pretty good the header needs welded, and for some reason when going into second gear i've got to pull the shifter to me and down. If i put two fingers on top the shifter and shift down it will go into fourth gear, i ask him about it and he said the tranny and the transfer case where out of a commanche, he said that was better cause it was gear to gear, not sure what do you guys think.
slamin04 is offline
post #21 of 22 Old 08-20-2011, 02:20 PM
clarkjdg
clarkjdg's Avatar
i really like the YJ interior, im going to look at a 93 Yj in the morning not sure about it yet tho, he just put a 4 rough country, lift and shocks, their is no tcase drop on it. onistly it looks like he did leafs and shocks thats it. here is a pic.
Well when I put my 8.8 in mine I had to pull the tcase drop "off" because the 8.8 raised the angle to where it was suppose to be and didnt need to be there anymore and I added a SYL and new dshafts anyway, check and see if its got a 8.8 rear axle, if it does "Dance in the Street" AFTER you pay for it!!!!! It sounds like what your saying on the shifter is if you just "drop" it down from first its going to the center position which is above 4th which is where it should go when you just drop it out of any gear you have to direct it to what you want it to go to, anytime you just kick it out of any gear, and it own its on unless you are directing it, it will go to the center so you know where you are at that time that way you can shift up, or shift down.
LIVE EVERY DAY LIKE IS WAS YOUR LAST...
/_|__\___\
[n___n_[*lllll*]
(o) )-(o) )-*-) )
88 YJ, Smittybilt SRC Front, Side, and Rear Armor, Family Roll Bars, TJ Flares, and Half Doors
4"Leaf, 2"Body, and 1"Leaf Lift, 4.10 Geared Dana 30 Posi with Cable Engage, Ford 8.8 Posi, With 33s BFGs MT KM2
Everything "Black" Inner, Under, and outer "Black" on the Body is "Bed Linered" and I will be Thru the day that I Die!
clarkjdg is offline
post #22 of 22 Old 08-20-2011, 06:31 PM Thread Starter
slamin04
2011 JK Wrangler
well not really going to center, i have got to pull it, its not smooth like the rest
slamin04 is offline
Lookin at an '07 tweekedknee JK Wrangler Technical Forum 6 02-26-2011 02:35 AM
If any one is lookin mouse Wrangler General Discussion 1 06-19-2009 02:06 PM
how much am i lookin at?? wegotj TJ Wrangler Technical Forum 6 08-26-2007 07:33 AM
lookin for a yj!!! bmx_hb_guy YJ Wrangler Technical Forum 17 02-14-2007 09:52 PM
Lookin at 8.8's and got Q's??? UCF YJ'r YJ Wrangler Technical Forum 17 02-08-2007 09:21 AM
