Look up part numbers - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Look up part numbers
HID's from RuffStuff!Ruffstuff Axle Simple Swap Kit!The Original 3/8" Ruffstuff Diff Cover!
Unread 12-01-2008, 09:08 AM   #1
Macklin96
I am doing a 4.0 swap in my 94 yj. Need to look up part numbers for the frame motor mount brackets. Anyone know them or a place to find them? I found them for a tj but dunno if they the same. It will be 2 brackets and 2 reinforcment steel plates i believe
Macklin96 is offline   Reply With Quote
Unread 12-01-2008, 09:48 AM   #2
Leans93
She's my density...
Leans93's Avatar
I'm in the middle of my swap now. Not sure of the part number but I may be able to find out when I get home. I got mine at the dealer and they were about $60 each. I'm about 99% sure they are dealer only.
They only came with the bracket and not the support piece underneath. I just used some steel and fabbed up my own.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline   Reply With Quote
Unread 12-01-2008, 09:57 AM   #3
Leans93
She's my density...
Leans93's Avatar
I was able to find the part numbers.
52040335 and 52040333 most likely.
M.F. Leans
Unread 12-01-2008, 10:24 AM   #4
timatoe
You can use this site to find dealer numbers and order parts too if needed.
http://www.berrysprinter.com/jeepparts.php
timatoe is offline   Reply With Quote
Unread 12-01-2008, 10:40 AM   #5
rivahrat
If you can look in my gallery you will find a catalog cut of the engine mount page with all the factory part numbers.
[B]IF IT AINT A JEEP IT AINT WORTH DRIVING![/B].
95 Wrangler YJ
rivahrat is offline   Reply With Quote
Unread 12-01-2008, 12:06 PM   #6
wildman90
one of the best places to look for part numbers is www.rockauto.com. they list the part number for each manufacturer and even have a reverse lookup (sort of)
wildman90 is offline   Reply With Quote
