longer shocks - JeepForum.com
post #1 of 2 Old 04-23-2010, 03:32 AM Thread Starter
rudedogg457
longer shocks
i installed a 4" rc lift and 1 in shackles and my front shocks seem to look a little short where can i get longer shocks
rudedogg457 is offline
post #2 of 2 Old 04-23-2010, 04:16 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Don't just buy 'longer shocks', measure what you have and buy what you need, the right part. Look at MFGs web sites for their product specs to find the right number to buy.
With the truck in the driveway:
0) make sure you have adequate bump stops to prevent tire/metal contact.
1) Measure the top to bottom mounting point distance (ML).
2) Measure he gap between the axle and the bump stop (BSG).
3) Buy a shock with the compressed length equal to ML-BSG-1/2".
The extra 1/2" will ensure the shock is not the limit on compression (bad). The max droop will just be what it is. If you want more droop, move the mount points further apart (make ML longer).
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
How do i tell if i need longer shocks?? phillsam YJ Wrangler Technical Forum 8 05-01-2009 03:34 PM
Longer shocks? TarHeel04 TJ Wrangler Technical Forum 2 05-01-2009 12:04 PM
Do you have to run longer shocks with BB BoostedTJ TJ Wrangler Technical Forum 12 04-14-2009 09:38 PM
Longer Shocks Brandon_YJ YJ Wrangler Technical Forum 6 03-18-2008 07:04 PM
Longer shocks DBLJ TJ Wrangler Technical Forum 4 02-20-2008 09:38 PM
