Long U bolts for SOA leaf replacement - JeepForum.com
post #1 of 14 Old 10-14-2013, 11:59 AM Thread Starter
fishtruck
1987 YJ Wrangler
I am stuck on finding the u-bolts for the front dana 30 axle, 1987 YJ.
I have found re2420 kit - but some raters have said the u bolts are not long enough for SOA (7 inches in my case) and the dimensions are not listed anywhere. Email pending from rubicon express.
A am looking for 1/2 x 2.5 (or 2.55?) x 7 or 8 inch u-bolts x 2. I can only find them 6 ish inches long.
and
1/2 x 3.5 x 7 or 8 inches. I found these in 5/8 inch only.
Anyone know any good sources?
Further commentary... I noted that the previously installed U bolts do not even come through the nut. Definitely too short!
fishtruck is offline
post #2 of 14 Old 10-14-2013, 12:03 PM
Bong_Holyeo
Ruffstuff ubolts are all 10" long but are 5/8" thick not 1/2. cant say enough good things about their products
http://www.ruffstuffspecialties.com/...g/U-BOLTS.html
Bong_Holyeo is offline
post #3 of 14 Old 10-14-2013, 12:38 PM
calvynandhobbs
calvynandhobbs's Avatar
x2 Perches, plates and ubolts for my SOA all came from RuffStuff
94 YJ - work in progress
calvynandhobbs is offline
post #4 of 14 Old 10-14-2013, 12:44 PM
fratis
fratis's Avatar
You definitely want to go with a size up on ubolts. Make sure your perches aren't too tall. I haven't used a set yet that I didn't first cut down. No reason for them to float the pack 2-3 inches from the axle tubing.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #5 of 14 Old 10-14-2013, 01:01 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I have all my ubolts custom made on the spot at a truck parts house.
Luck Favours The Prepared
Anticanman is offline
post #6 of 14 Old 10-14-2013, 02:10 PM Thread Starter
fishtruck
1987 YJ Wrangler
Thanks guys.
post #7 of 14 Old 10-14-2013, 05:18 PM
jbolty
jbolty's Avatar
These are the NAPA numbers for the stock size bolts but upsizing is a good idea.
650-4076
650-4002
jbolty is offline
post #8 of 14 Old 10-14-2013, 05:37 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
When I still had a HPD30 and did a SOA conversion, I used the RE2420 ubolts & they were plenty long enough.
Unless they have changed to a shorter length, they should be fine SOA unless there's some sort of oddball perch being used.
I would have called RE.
Joe Dillard is offline
post #9 of 14 Old 10-14-2013, 08:47 PM
TSEJEEPERS
I would also get the plates from ruff stuff.
It is pretty easy to bend the stock plates.
http://www.ruffstuffspecialties.com/.../25J-UPLT.html
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #10 of 14 Old 10-15-2013, 05:59 AM Thread Starter
fishtruck
1987 YJ Wrangler
I was going to use the plates that are already there and drill them for bigger u bolts of needed... but... I just ordered the new plates instead. Less rusty stuff the better I suppose.
post #11 of 14 Old 10-15-2013, 06:18 AM
WDNewman
http://www.generalspringkc.com/product_p/u%20bolts.htm
This is where I'm going. The PO had U bolts that were about 3" too long installed and did not cut 'em to size. If I don't change them one day I'm going to hit a stump.
WDNewman is offline
post #12 of 14 Old 10-15-2013, 09:25 AM
TSEJEEPERS
Cut them down.
You do not need to remove them to do this.
You can use a saw zaw or a angle grinder with a cut off wheel.
post #13 of 14 Old 10-15-2013, 01:00 PM
ldso
Originally Posted by TSEJEEPERS View Post
Cut them down.
X2. I didn't know to cut them down when I installed my SUA lift, I did later with the grinder. I need to trim the rear ones since I removed the degree shims.
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #14 of 14 Old 10-15-2013, 08:36 PM Thread Starter
fishtruck
1987 YJ Wrangler
Regarding the perches... the ones I have are about 1.25 inches tall. I see the ones from ruff stuff appear to be about .75 inches tall. I have a traction bar - so hopefully axle wrap won't be an issue. BUT, I am going from wrangler springs to reverse eye 1.5 inch lift springs and adding a 4 degree shim to the rear axle. Maybe I should replace the perches too while I am at it? (I don't want too much more lift).
