Long crank, start. every time - JeepForum.com
post #1 of 10 Old 08-21-2011, 11:39 AM Thread Starter
mbeck94
1977 CJ7
94 yj 2.5l. the only codes are 12 and 33, so nothing there, it will crank but not start. the only! way to get it to start is to keep cranking, i know this is bad, but its the only way, not even turning the key on off on off get it. to start you have to crank about 30-45 seconds until the CEL comes on, then turn the key off and it will start, but on if you keep your foot on the gas or it idles too low. after thats its fine, this happens hot or cold, any ideas?
98 XJ-sold
94 YJ-sold
00 WJ- sold
77 CJ- sold
mbeck94 is offline
post #2 of 10 Old 08-21-2011, 11:55 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
The passage to the idle air bypass valve may be blocked. You might need to pull your throttle body off and clean it. The TPS sensor could also be bad. Just a couple things it could be.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #3 of 10 Old 08-21-2011, 12:24 PM Thread Starter
mbeck94
1977 CJ7
where is this idle air bypass valve you speak of!
98 XJ-sold
94 YJ-sold
00 WJ- sold
77 CJ- sold
mbeck94 is offline
post #4 of 10 Old 08-21-2011, 12:38 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
It will be on the side of the throttle body.
5.7YJ is offline
post #5 of 10 Old 08-21-2011, 03:14 PM
Mark05059
try turning the key to on... (dont engage the starter) until you see the check engine light come on and then try and start it.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #6 of 10 Old 08-21-2011, 03:27 PM
jladams80
sounds alot like it may require brain surgery soon. that is where they replace the three capasitors in the ecu. mine did the same thing. it eventually took 20 minutes to see the checkengine light finally come. did the "brain surgery" fixed it rite up. im not a pro butthats what happened to me. the nice thing is that the who;e process cost about $6
jladams80 is offline
post #7 of 10 Old 01-18-2013, 02:45 PM
stompjrkz400
I have this exact problem, i need a write up on the ecm cap replacement, im a computer tech, so its normal stuff for me, but do you change rating on the caps?
stompjrkz400 is offline
post #8 of 10 Old 01-18-2013, 02:53 PM
Mark05059
search in this forum for brain surgery. The caps are the same rating as what they were when new. Radio shack is a good source for them.
1998 ZJ 5.2 Auto
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
post #9 of 10 Old 01-18-2013, 03:51 PM
pete1991YJ
X3 on the brain surgery, this is the classic symptoms. The good news is that the parts to fix it are less than $5 and some effort. Instead of hundreds for a new computer. I think the write-up is in the FAQ's at the top of the page.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #10 of 10 Old 01-18-2013, 04:05 PM
stompjrkz400
Im stuck viewing the site with a cellphone right now, i cant seem to find the thread, I searched for Brain surgery and ecm
Long crank time sprtplt JK Wrangler Technical Forum 9 04-09-2014 10:10 AM
Fixing Long Crank Time..? Baerr YJ Wrangler Technical Forum 2 03-22-2011 04:39 PM
Takes a long time to crank cntryboy97 TJ Wrangler Technical Forum 9 09-13-2009 10:00 PM
long crank time FIXED nasty habit TJ Wrangler Technical Forum 5 11-10-2008 08:54 PM
Long crank time? dth JK Wrangler Technical Forum 13 08-19-2007 08:25 PM
