Loctite IRL vs FSM - JeepForum.com
post #1 of 6 Old 06-18-2013, 01:27 PM Thread Starter
Dwarf
1987 YJ Wrangler
Loctite IRL vs FSM
Hey guys,
I have the FSM, but was wondering if the gurus here could give me some practical advice from life experiences.
Should I use red loctite on:
Flywheel to cam
Clutch Plate to flywheel
Exhaust Manifold to block
Exhaust/Intake manifold to block
Should I use blue loctite on:
Exhaust manifold to towntube collector
Carburetor mounting studs
Oil Pan bolts
Bellhousing to block
bellhousing to AX15
U-Joint retainers
I'm getting gun-shy on this project. I've rebuilt older chevrolets before and I've never had this many bolts snap on me (yes I used PB Blast, yes I let it sit and reapplied, etc)
I appreciate your advice - D
Dwarf is offline
post #2 of 6 Old 06-18-2013, 01:51 PM
Jeepsr4me
No on the exhaust/intake manifold to block.
No on any thing but anti seize on the exhaust down tube.
I would not waste time with putting anything on the oil pan bolts. Or the engine to trans bolts.
Jeepsr4me is offline
post #3 of 6 Old 06-21-2013, 09:21 AM Thread Starter
Dwarf
1987 YJ Wrangler
Nothing on the intake/exhaust to head? I thought surely you would on those guys.
Dwarf is offline
post #4 of 6 Old 06-21-2013, 09:37 AM
Jeepsr4me
I have only put together and couple hundred of these engines, so do as you want. If I find a issue that needs a locking fluid I use it. If I dont then I dont worry about it..
post #5 of 6 Old 06-21-2013, 12:19 PM
Siva283
I didnt use locktite on any of those bolts when I did my engine and trans replacment. I just torqued them to spec. 5 months 20,000 miles no issues.
Ask me how I know...
Siva283 is offline
post #6 of 6 Old 06-21-2013, 06:10 PM
pete1991YJ
Don't bother with loctite on the exhaust at al. The heat will neuter it and it won't hold anything. The only place I've ever used loctite is on the connecting rod nuts. Its the only place that really needs it. Otherwise just be very clean, no crap in the threads -- and torque it to spec as Siva says. It'll hold.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
