lockrite or no slip - JeepForum.com
post #1 of 7 Old 03-05-2002, 04:13 PM Thread Starter
BigD1634
2012 KK Liberty
lockrite or no slip
i am looking at lockers and don't know which is better for me. i go off road about 3 or 4 times a month, usually long days though. i do quite a bit of high way driving. what do you suggest.
BigD1634 is offline
post #2 of 7 Old 03-05-2002, 09:51 PM
RodeoRob
RodeoRob's Avatar
need more info... which axle you looking to lock? front/rear? cost a consideration?
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 36x12.50 TSLs, D44 front, 14bff rear, locked by OX and Detriot, suspensions by Jeep and Chevy, high steer conversion, 5.13 gearing and Teralow in the case.
RodeoRob is offline
post #3 of 7 Old 03-06-2002, 01:10 AM
evilpsych
evilpsych's Avatar
the general consensus i've seen around here and on other sites/magazines, is the no-slip.. it's quieter and stronger than the plain lock-right, although it's made by the same people. if $$$ is a concern, get the lockright, as the no-slip is nearly twice the cost..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
post #4 of 7 Old 03-06-2002, 04:47 AM
MY95
MY95's Avatar
BigD Im running close to the same set up as you and from what I have heard the no slip would be the better way to go for a daily driver. Evilpsych is right they do cost around a $100 more but I think it would be worth the extra $$$. This is what I plan to do in the next month or so.
95 YJ 2.5L w/3.5" Superlift, 1" BL
33x13.50 Swamper LTB on 15x8 Eagle 589s
Mile Marker E12000, Optima Yellow Top
MORE 5/8" Boomerang shackles, Hi-Lift Jack
4.0 TB w/ poweraid spacer, Rustys air tube, K&N filter
WHITE Jeep club member # 007
MY95 is offline
post #5 of 7 Old 03-06-2002, 04:48 AM
MY95
MY95's Avatar
MY95 is offline
post #6 of 7 Old 03-06-2002, 08:30 AM
RodeoRob
RodeoRob's Avatar
I'd save you're money in the front, lockright and no-slip are gonna behave the same. For the rear, i'd look at the no-slip.
-Rob
Robert Gorrell
RodeoRob is offline
post #7 of 7 Old 03-06-2002, 08:56 AM
gifargis
I'm running the no-slip in rear D35 4.10's
and its only brutal in the rain or snow.
the jeep goes sideways ALOT...
other than that you can spin tires in any occasion any weather and will add additional power to the wheels..
Was it worth it YES
See y'll on the trail.
gifargis is offline
Lockrite vs Detroit 00jeepsahara TJ Wrangler Technical Forum 1 04-12-2007 01:17 PM
Lockrite in a D44 Wynne TJ Wrangler Technical Forum 6 02-13-2007 04:08 PM
Powertrax VS Lockrite dupwee00 TJ Wrangler Technical Forum 7 06-27-2006 06:13 PM
AUSSIE vs. LOCKRITE Texas TJ TJ Wrangler Technical Forum 29 02-06-2006 07:28 PM
Aussie or Lockrite mwhorseman TJ Wrangler Technical Forum 3 04-06-2005 06:41 PM
