lockright locker in a dana 30 - JeepForum.com
post #1 of 12 Old 04-13-2006, 07:48 AM Thread Starter
bryan-2kevo
i am getting ready to install a lockright locker in my front and rear axles (dana 30/35) i was wondering how hard is the locker on the front axle and ball joints, and with regular driving?
bryan-2kevo is offline
post #2 of 12 Old 04-13-2006, 08:28 AM
dbguync
I have a lockrite in my D30. I have broken the passenger side u-joint, but the Lock rite has held up well. On the road its not noticable. I also had one in my D35 that self destructed on the trail one day. Just be certain its installed correctly and i think you'll get good service out of it.
87 YJ, 3.5 BDS kift, 33x12.5 ProComp MT's, 4.2, Nutter bypass, Weber carb, HEI ignition, Lockrite in the front , 8.8 in the rear, 456 gears all around. Oh, and a warn winch, etc, etc, No money left,
dbguync is offline
post #3 of 12 Old 04-13-2006, 08:31 AM Thread Starter
bryan-2kevo
is there any problems with driving on the road w/ a front locker in 2WD?
post #4 of 12 Old 04-13-2006, 09:10 AM
dell2028
dell2028's Avatar
Won't notice it because the YJ front axle is 3 peices. The passenger side locks together when you engage 4WD and the vac. accuator pulls a fork moving a collar over the two peices. Once the splines match up the collar slides over and the front driveshaft is being spun by the transfer case and the tires are spinning. I locked my passenger side axle like a TJ's and still can't notice my aussie locker on the road. Off road, its a whole different ball-game. Front now has much improved traction.
95 YJ, D30/8.8 w/ 4.88s, SOA, 35x14.50x16.5 Pit Bull Mud Dawgs, 101" Wheelbase, Custom Front Bumper, Winch, Custom Rear Tow Points, Traction Bar, Aussie Locker in front, 20 Gal. Gas Tank modification, Hurculiner Tub, Custom Rear Bumper, SYE and CV shaft, BTF Cross-over Steering, RCI 2191 fuel cell, BTF Rockers, RE 1.5" SOA springs up front and XJ springs in the rear
Down the line a bit...engine swap, the list goes on.
dell2028 is offline
post #5 of 12 Old 04-13-2006, 09:34 AM Thread Starter
bryan-2kevo
when i talked to 4wd hardware about it, they told me that i would have to get the lock out hub conversion to be able to drive it on the road. is this true? or are they just wanting more $
post #6 of 12 Old 04-13-2006, 09:49 AM
Punisher
Total BS
You dont need lockout hubs to run a lockright in a YJ. The CAD essentially does that (only on one side though)
Punisher is offline
post #7 of 12 Old 04-13-2006, 10:50 AM
dell2028
dell2028's Avatar
Yeah, the hub conversion thing is total BS. I really can't beleive they told you that. Like I said before, because of the axle disconnect it will be like driving with an open diff when not engaged.
dell2028 is offline
post #8 of 12 Old 04-13-2006, 10:55 AM Thread Starter
bryan-2kevo
sweat! well thank you guys a ton!
i am getting the locker for free off of my brother, he is putting in a kingpin dana 60 front and a dana 70 rear into his 83 CJ7, so if the part fits i was going to use it. I have another friend who is putting in a dana 44 rear end so i will buy his rear lockright locker for $100.
post #9 of 12 Old 04-13-2006, 11:06 AM
ghiradelli777
how long do you think it takes to do the frint locker???
1992 YJ Sport White 4.3 swap in progress
Eagle Scout Jeep Owner
ghiradelli777 is offline
post #10 of 12 Old 04-13-2006, 11:32 AM Thread Starter
bryan-2kevo
i believe just a few hours 2-3 at most. depends on how easy it is to get the front hubs off and axle shafts out.
post #11 of 12 Old 04-13-2006, 12:17 PM
yesterdaylight
during the install the hubs were the hardest part for me, and i broke a bolt accidentally so be sure to work those 3 bolts progressively in and out as you go spraying em with PB blaster or something. take your time with them because when they break they are a ***** to get out.
Green Jeep Club Member #172
Low Output 4 Cylinder Jeep Club Member # 23
Green 1995 4 Banger
If only my pocket was as green as my Jeep :D
yesterdaylight is offline
post #12 of 12 Old 04-13-2006, 12:29 PM Thread Starter
bryan-2kevo
I had replaced the passenger hub last spring, so i just worry a little bit about the drivers side comming off, we used plenty of anti-seize!
Lockright E-Z Locker VS. Aussie Locker Wheels4186 TJ Wrangler Technical Forum 42 10-19-2010 05:39 PM
Powertrax Lockright locker for the Dana 30, have some ??? Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 17 10-07-2009 10:11 AM
Would you buy a used Lockright Locker? Regulator TJ Wrangler Technical Forum 23 01-08-2009 06:20 PM
Dana 30 Lockright Locker Problem Chris @ GATR TJ Wrangler Technical Forum 12 04-20-2007 10:04 AM
lockright locker General Purpose YJ Wrangler Technical Forum 3 08-07-2006 04:15 PM
