Lockout hubs - JeepForum.com
post #1 of 7 Old 08-25-2012, 08:05 AM Thread Starter
inspector_s
Lockout hubs
I have a 1995 Jeep wrangler that I am setting up to tow behind a camper. Is it advisable to install lock out hubs on the front wheels or is just shifting the transfer case into neutral OK? I have the 2.5 engine with a standard transmission.
inspector_s is offline
post #2 of 7 Old 08-25-2012, 08:15 AM
Cajun90YJ
Put your transfer case in neutral and transmission in 5th and pull away. lockouts would not hurt but are awful expensive, if you were really worried about it you could pull the driveshaft.
Cajun90YJ is offline
post #3 of 7 Old 08-25-2012, 09:11 AM
ltrail
1984 XJ Cherokee
I am curious as to why you put the trans in 5th? I would think both in neutral would be fine.
I do agree locking hubs are too expensive for what you're doing. Think of it this way(in reference to front driveline) if you drove the jeep on this trip instead of towing it would have the same effect on the front drive. Either way the front axle will be free to spin due to the vac disco. Drive or tow the front is in neutral and would act the same regardless. No worries there.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #4 of 7 Old 08-25-2012, 09:19 AM
Louie4
Rickety Wrecked Son!
Louie4's Avatar
Here's some good reading.
http://www.jeepforum.com/forum/f12/t...plate-1076065/
Lou
YJOTM July 2012
YJOTM February 2014
Louie4's YJ Build
Poison Spyder Fender Install
Warn M8000 Rebuild Adventure
University of Georgia
Louie4 is offline
post #5 of 7 Old 08-25-2012, 10:18 AM
ltrail
1984 XJ Cherokee
Well done Louie!
ltrail is offline
post #6 of 7 Old 08-25-2012, 10:28 AM
UltimatE
Resident Audio Guru
UltimatE's Avatar
The idea with putting the transmission in gear (Park in an automatic) for flat towing is because you don't want the transmission internals spinning without lubrication. This is mainly an issue only with automatics, where the pump is driven from the input shaft.
If you're going to be flat towing really long distances, I would go as far as removing the driveshafts and just letting the axles free wheel with the least amount of load, and zero wear on your transmission and/or transfer case.
-Matt
White '94 YJ Sport
Black '98 ZJ Laredo - 45x60 Surco Rack - 2" Budget Boost, Addco Front Swaybar
Project (s)Low - A build log.
UltimatE is offline
post #7 of 7 Old 08-25-2012, 12:32 PM
Cajun90YJ
Putting it in 5th has to do with the transfer case possibly causing the transmission output shaft to turn if the transmission is in neutral starving the trans for lubrication, here is a thread discussing it.
http://www.jeepforum.com/forum/f104/...92/index2.html
warn dana 30 lockout hubs moofielip TJ Wrangler Technical Forum 0 04-29-2011 12:14 PM
Lockout hubs on JK Howdy JK Wrangler Technical Forum 29 01-28-2010 10:48 AM
Please explain manual lockout hubs to me roundlitefan TJ Wrangler Technical Forum 14 07-27-2009 04:10 PM
Sourcing Warn Lockout Hubs DavidJohnson TJ Wrangler Technical Forum 9 01-19-2009 09:51 AM
lockout hubs tjscoot00 TJ Wrangler Technical Forum 1 12-01-2008 09:36 PM
