Locking Hubs - JeepForum.com
post #1 of 17 Old 09-15-2013, 07:42 PM Thread Starter
the_hub49
Locking Hubs
Is it possible to install locking hubs on my front axle? and if so has anyone done something like this and what kinda work does it entail? I assume it would help a little with MPG, and maybe with wear and tear on the front diff/axles. If most other 4WD rigs have them why not Jeep?
the_hub49 is offline
post #2 of 17 Old 09-15-2013, 07:44 PM
superj
Jeep used to have them, like other manufacturers used to have them. No one does anymore
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 17 Old 09-15-2013, 07:52 PM Thread Starter
the_hub49
why not any more? Would installing a set do me any real good?
post #4 of 17 Old 09-15-2013, 07:55 PM
Old4X
1990 CJ7
There was a kit made by Warn (?) for the YJs. It was very expensive, and is no longer available. I haven't seen one in 8 years.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 17 Old 09-15-2013, 07:56 PM
TSEJEEPERS
Warn used to make a conversion but I do not think they make them anymore.
Mile Marker makes one and so does Alloy USA.
Here is one made by Yukon.
http://completeoffroad.com/i-2757088...s-yawu-07.html
You will also have to replace the inner axle shaft if you are not running 297 u joints.
You are looking at $1000.00 or more. Thats alot of gas!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #6 of 17 Old 09-15-2013, 07:57 PM
ROWA
ROWA's Avatar
There are kit's out there, but you would be better of using a Dana 44 or 60.
94 YJ Sahara
The best Engineering is no match against natural Stupidity.
ROWA is offline
post #7 of 17 Old 09-15-2013, 08:19 PM Thread Starter
the_hub49
Ya ive been looking at the kits all night, and reading up on the ups and downs. As for front axles what is good upgrade for mild off road use?
post #8 of 17 Old 09-15-2013, 08:21 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Your stock front axle disconnects the passenger shaft and saves gas by not turning the front driveshaft.
Luck Favours The Prepared
Anticanman is offline
post #9 of 17 Old 09-15-2013, 08:23 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Locking hubs are dinosaurs, and there's a reason they're extinct.
What's the problem with keeping the Dana 30?
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #10 of 17 Old 09-15-2013, 08:27 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Sorry, but I'm not buying that.
Typically, YJs with 4.0/manual transmissions & CADs get around 15 MPG, this is almost certain.
Oddly enough, similarly equipped TJs without CADs get the same MPG.
Just saying, don't drink the Kool-Aid.
Max
Mean Max is offline
post #11 of 17 Old 09-15-2013, 08:29 PM
crackedcornish
the small 5 on 4.5" bolt pattern of the YJ doesn't leave a lot of room for a locking hub assy., so the ones that are (or were) available aren't as strong as the ones for larger diameter hubs/wheel bolt patterns
ETA: but Max I miss the manual locking hubs that I had on my CJ...there was just something about getting out at the head of the trail, airing down and turning the hubs, that I liked
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #12 of 17 Old 09-15-2013, 08:41 PM
squarelite
My jeep came with the warn hub conversion. I likely as it is a simpler setup than the cad. There is less chance for error with the cad removed. If I had to do it, I would dump the money into a hp 44.
squarelite is offline
post #13 of 17 Old 09-15-2013, 08:45 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Max
Max,
As I don't dare disagree with you I'm going to compare apples to apples. My jeep with the cad got 2 more mpg than when I swapped it for a solid shaft. Overall, I think the big picture is "Don't buy a jeep if you're going to worry about gas mileage". On a different note, how are the Mosquitos down there? They made the news.
post #14 of 17 Old 09-15-2013, 08:53 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Max,
I'm pretty sure that a 2 MPG difference can depend on how you're feeling that day, or what tunes you're listening to. Either way, in my opinion it's negligible.
Not worth spending $$ on, really.
Yep, my county (Martin) leads the count on dengue fever cases. It's pretty bad.
Max
Mean Max is offline
post #15 of 17 Old 09-16-2013, 07:35 PM Thread Starter
the_hub49
wow that took off what does CAD stand for. And I also enjoyed getting and locking in my hubs. besides the Dana what other front axles can i swap in??
