Lockers - Page 2 - JeepForum.com
post #16 of 36 Old 04-21-2013, 10:57 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Yes and yes sometimes. But not all the time.
Luck Favours The Prepared
Anticanman is offline
post #17 of 36 Old 04-22-2013, 06:42 AM
StanF
Originally Posted by smartin1 View Post
I want to put lockers on my yj but I know nothing about installing them I only know the purpose, can someone lead me in the right direction if this is something I can do myself, what to buy, what tools I'm going to need how much money I'm going to be into this for And keep in my I have zero experience with differential gearing. I have a dana30 in front and dana35 in rear
Here's a great writeup for you. It's for a TJ, but the YJ Dana 30 is mostly the same. The only difference is in the CAD and intermediate driveshaft. Should take you a day at the most (3-4 hours if you are efficient). Put on a Solid differential cover at the same time.
http://www.jeepforum.com/forum/f9/ex...hafts-1234745/
http://www.solidaxle.com/ProductCart...1&idcategory=7
StanF is offline
post #18 of 36 Old 04-24-2013, 08:50 AM
Wrangler11
Wrangler11's Avatar
An Aussie is a great way to go as long as you don't use 4wd a lot in winter. I had an Aussie in my tj and absolutely loved it. It'd make a noise here and there but it wasn't bad. If you don't feel confrontable installing it I think I paid about $250 to have it done so it wasn't outrageous.
I live in Chicago and never really needed 4wd with the wrangler. I did engage 4wd a few times to see how it handled and anything over 10-15 mph it was a different vehicle and because of that I am going with a selectable locker in the front axle.
2002 Grand Cherokee Limited
1994 Toyota Land Cruiser (camping offload toy)
Wrangler11 is offline
post #19 of 36 Old 04-24-2013, 11:03 AM
YJames90
YJames90's Avatar
Originally Posted by kjg26 View Post
Any clicking? Noise?
Why would a clicking noise be a concern if you know that the locker was the source of the noise?
Heck! Its not even a noise but more of an audible click that is ONLY heard when 4wd is engaged.
A clicking noise from an unknown source like a bad u joint would be a concern, not a properly functioning locker
My 2.5 to 4.3 swap thread
YJames90 is offline
post #20 of 36 Old 04-24-2013, 11:47 AM
bogleparsons
The clicking actually lets you know the locker is functioning properly and ratcheting like it should.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #21 of 36 Old 04-24-2013, 12:12 PM
kjg26
kjg26's Avatar
When in two wheel drive...the front shaft will spin too right?
Black 1993 YJ 4.0, 5 Speed
Slowly but surely getting better and better. Trailer build soon!!
kjg26 is offline
post #22 of 36 Old 04-24-2013, 12:38 PM
YJames90
YJames90's Avatar
It only clicks in turns. Alot of my wheeling includes driving straight too, Then what?. That sound is not there to let you know if its operating correctly. Its a bi-product of its function.
My Aussie rear clicks on the road in the 8.8 but I rarely hear it. Maybe its because the 8.8 is so thick and deadens the sound or maybe its because the 4.3 duel exhaust.
Aussies front and rear are very safe off and on the road in all weather conditions
YJames90 is offline
post #23 of 36 Old 04-24-2013, 12:46 PM
kjg26
kjg26's Avatar
In the rear do you have the same issues with tire wear as a full case locker?
kjg26 is offline
post #24 of 36 Old 04-24-2013, 01:15 PM
YJames90
YJames90's Avatar
Its not my DD. The Jeeps sees the inside of the garage most of the time so i dont know
YJames90 is offline
post #25 of 36 Old 04-25-2013, 05:53 AM
bogleparsons
Tire wear is whats stopping me from putting an Aussie in my 8.8.
Love it in the D30 but afraid of the damage it would do on my new meats
I drive like 50/50 on/off road
post #26 of 36 Old 04-25-2013, 01:27 PM
calvynandhobbs
calvynandhobbs's Avatar
I ran a Detroit in the rear of my TJ for a couple years and never had abnormal wear on the rear tires. I also had an Aussie in the front during that same time period. I welded the rear axle in my XJ and that one wore through tires. LOL
94 YJ - work in progress
calvynandhobbs is offline
post #27 of 36 Old 04-26-2013, 09:35 PM
Flajeeper1
1987 YJ Wrangler
Bogle, update your profile, it says you still have a D35. On the rear axle, I finally bit the bullet and installed an Auburn electric locker and WOW what a difference from running a Detroit! OP, run the front locker and you're good to go. Leave the D35 as is and when you want to upgrade to a stronger axle spend the money for a locker. (I have a great deal on an Aussie locker for a D35..... ).
Flajeeper1 is offline
post #28 of 36 Old 04-26-2013, 09:46 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
How are you liking the ECTED? Did you get it dialed in? Its gotta be worn in before it will unlock after stressful situations.
post #29 of 36 Old 04-26-2013, 09:52 PM
plym49
Yes, with a front lunchbox-style locker your front driveshaft will spin all the time.
plym49 is offline
post #30 of 36 Old 04-26-2013, 09:57 PM
Flajeeper1
1987 YJ Wrangler
You will probably need to balance your front driveshaft if you use the jeep as a DD.
